Topic: Project Evolution *** Project Complete **** Wednesday July 9, 2014 (Read 1533295 times) previous topic - next topic
Reply #3225
here's another head on shot
and a down shot
Reply #3226
Quote from: Thunder Chicken;382989
God, it's hard to believe that's the same car as this
I can't remember what the car used to actually look like unless I look at the pics
Reply #3227
Before....
After....
Reply #3228
Don't forget the distributor in the middle between the scoops. If you can make it work, make one for me.
Reply #3229
Quote from: vinnietbird;382997
If I can make it work.... I can have them molded for us... I know a guy. he said anything I need, just make a pattern, and he'll make it
I'll play with it when I play with the radiator cover, and battery cover, and all my wiring covers
Reply #3230
It looks great :). Maybe I missed it but how did you get the front end back down? It sits really nice now.
Reply #3231
I put air shocks in the back... the front never went down
Reply #3232
Keep me posted on those things.
Reply #3233
With the ram air, it would have to go to an air box, then to the t-body. ....and keep water out of the filter. Hmmmm.....yes, I could use one.
Reply #3234
Now if you just get some headlights on it it'll look all done:D
Reply #3235
Quote from: vinnietbird;383033
I will study the design from the TC.. I still have the plastic part from the underside of the hood
Reply #3236
Even if just the passenger side scoop would suck in air maybe.....depending on available space due to the distributor and all. The a/c compressor bracket that bolts to the front of it, I left off. Just have the 4 big bolts at the bottom holding mine on. Been fine for quite a while, which may help in needed space.
Reply #3237
looking at the pic...if I shortened the tube going to the TB and flipped the airbox over, it just might be in the right place to connect up to the scoops behind the upper rad hose.
I'll play with that tomorrow and see where things end up, and take some pics and measurements with the hood closed
Reply #3238
Sweet. I'm in.
Reply #3239
stay tuned for tomorrows new episode of ..."Project Evolution"
