Topic: injector cleaning (Read 1745 times) previous topic - next topic
injector cleaning
Hey guys how hard is to remove the injectors of my 88 v6 want to clean them and want to do the job myself  :america:  :sawzall:  :rice:
Re: injector cleaning
fuel injector cleaning<remove the upper half of cfi,, removed the lower injector (be careful on the screw or you will be taping a new hole).
gently pull the injector out
take a pointed tip screw start this screw into the brass bushing just at the top of the injector until it started to grab real good.
grab the screw with pliers and pulled real hard and out pops the injector screen that is molded to the brass bushing.
spray the injector screen assy down with starting fluid or something.
Next, blast it with the air compressor.
insert the screen assy back into the top of the injectors,, turn the injector upside down and tap it on the workbench which will seat the brass bushing part back in its seat.
re-install the injectors and man does make a difference.
the screen assy is only about a half inch long and about 3/16 in diameter.  Pretty fragile looking also.  I re-shaped the screen on one becase it was a bit sucked together.  I re-shaped it with a small ink pen insert.
