Topic: Body flex (Read 5977 times) previous topic - next topic
Body flex
it was drizzling a few days ago, and i was coming home from work, at a quick clip since i was on a straight section, and got on the brakes pretty hard for a turn, and my sunroof dripped on me, so later that day, i was doing about 85 on the highway with no one around, and i test it again, i got on the brakes, and the sunroof started allowing air in
ive come to realize, the body flex on these cars is pretty nasty
Re: Body flex
Well you also got a hole in your roof =)
Theres aways sub-frame connecters (which I want to get for my own coug) and a farther extent a roll cage to fix that
Re: Body flex
i plan on making my own subframe connectors, seeing as im learning to weld and im pretty  good with a cutting torch, and i have access to a lot of kickass supplies at work
Re: Body flex
You will be "very" happy when you install subframe connectors. You cannot beleive the difference those make in these cars!!! One of the best upgrades. I had a set of Mustang ones on my 87 XR7, and it was atotally different car afterwards. :D
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
Re: Body flex
even in a slide, i can feel the car flexing, even if it doesnt make the car handle better, i could see it making the car more consistant
which connectors did you have?
Re: Body flex
It's been so long, I don't remember the company. I know they were for 79-93 Mustang, they had the seat braces but I trimmed those off. Other than that they lined up great on my Cougar. I talk with my son and see if he remembers. :D
Re: Body flex
Hey Shawn here are the connectors that I have....
Subframe Connectors, Crossbar style for 1979-2000 Mustang, zinc finishSubframe Connectors, Crossbar style for 1979-2000 Mustang, zinc finish
HPM Crossbar Subfame Connectors are one of the first components to add to improve the structural integrity and longevity of your vehicle. These connectors are constructed of 1-1/4" x 2" 14 gauge tubing for high torsional strength without sacrificing ground clearance. installation is accomplished by bolting the crossbars to the chassis and welding the ends to the vehicles' subframes. HPM does not build, sell, install, or recommend bolt-in designs for any application. For a stronger and easier installation these connectors are contoured to match the floorpan and subframes. A vast improvement will be noticed in the 'tightness' of the car over uneven surfaces and during extreme maneuvers
HPM5400AZ
Re: Body flex
Hey Shawn-
Yes..the Fox bodies are a rigid as wet noodles.
It's pretty easy to to SFCs and weld-in is the way to go.  If you wind up going the make you own route and are working w/ 2" wide material for main tubes, I have some preformed crossbars (for support under the seats) made up from when I was selling mine.  I can sell the crossbars (and the seat hardware) pretty cheap.  Holler at me if you go that route.
You'd also me suprised how much improvement things like a STB and a lower chassis brace make on the feel of the front of the car as well.
Re: Body flex
i might get to ya in a couple of weeks, i may be able to get some tubing from work, if not, its still relatively cheap, and my buddy would let me use his welder, i just need to learn to weld well
