Topic: AOD or C4 or C6 (Read 4506 times) previous topic - next topic
AOD or C4 or C6
I am a C-4 guy all the way, Small Bulletproof design. have 2000 stall and freshly rebuilt for $450.00 at Local Trans shop here in Southern Alabama. I am running 3.55 locking Rear end. ..........I have heard the aod is pretty expensive to handle anything over 350 Horses.
AOD or C4 or C6
what are the weights of the 4 different tannys we are talking about?
c4,c5,c6,t5?
AOD or C4 or C6
Quote from: jcassity;191140
c4,c5,c6,t5?
and does anyone know the HP lose threw all the tranys
AOD or C4 or C6
Quote from: thunderjet302;190958
Neat :D . Any idea how much they cost now?
Bought mine used for 1500 w/stall converter, approx 1000 miles on it just a little age
AOD or C4 or C6
Quote from: TurboCoupe50;190890
AOD all the way... Been beating on a 3.8 SC version for 7+ years... Other than a Trans-Go shift kit and hardened shaft, it's stock(never apart)... Yea it's due for a freshening up, but I been saying that for three years...
If you drive the car any distance there's no decision, AOD...
My AOD has 9+ years 60K+ and then some on stock internals with a TransGo and hardened input shaft.
AOD or C4 or C6
Quote from: V8Demon;191188
The input shaft is the first thing to go on the AOD when it's in a high power application. Oh  I hope mine doesn't go out soon........:hick:
AOD or C4 or C6
THe loss thur a C4 is approx 25%
 The AOD loss is approx 30%
 But the 40%dropi in RPM is worth it.
Just my 2cents
AOD or C4 or C6
Here's an interesting read on horsepower lost through a driveline:  http://www.superstang.com/horsepower.htm
What's the Loss?
When we began to contemplate flywheel horsepower figures for our different combinations, we bantered about some concepts that can be deceiving.  Most enthusiasts have been exposed to the idea that flywheel and rear-wheel horsepower can be equated by factoring in a given percentage for drivetrain loss - the drag that occurs from all the items between the flywheel and the rear tires.  You may have seen factors such as 15 percent for stick-shift cars and 25 percent for automatics, applied by dividing rear-wheel horsepower by either 0.85 for stick-shifts or 0.75 for automatics.
Now take a time-out and consider the following.  Our original baseline indicated 195 hp at the rear wheels, which when divided by 0.85 equates to 229 flywheel horsepower, and implies that the drivetrain is absorbing some 34 horsepower.  On the other hand, our combination of blower and traditional bolt-ons netted nearly 340 hp on the Blood Enterprises dyno, which when divided by 0.85, equates to 400 flywheel horses, and implication that the drivetrain is now absorbing 60 hp.
Nothing has changed between the flywheel and the rear wheels on our '93 LX, so does it make sense to figure the drivetrain is now absorbing nearly twice as much power?  Such a concept just doesn't jibe in our little brains, so we asked a couple of people in the biz what they thought.  Lee Bender of C&L Performance and Paul Svinicki of Paul's High Performance are both well versed in evaluating Mustangs on the dyno, and they both agreed that extrapolating drivertrain horsepower loss via percentages is flawed.  Lee believes that the stick Mustangs experience roughly a 35hp loss through the drivetrain, whether they make 200 hp or 400 hp.  He did explain that ultra-high-powered vehicles - typically race cars - can be and exception to this rule, but that's a topic for another time.  Interestingly, a 35hp loss for stick-shifted drivetrains is strikingly similar to the difference between Ford's horsepower ratings and the rear-wheel numbers we've observed on dynos across the nation.  Hmmm...
I'd always always heard an AOD was in the 20-25% area.
AOD or C4 or C6
do ant of you guys have a tranns brake? im thinking about buying a tranny with a tranns brake to give me better launches
AOD or C4 or C6
Quote from: quicksilver;192007
That's basically for the race track only... Unless you have slicks(and I don't mean the average Drag Radial), all you're gonna do is burn up a bunch of tires...
AOD or C4 or C6
If you're going that route, you'd better think about having a custom driveshaft made, 31-spline axles, c-clip eliminators...and I would hope that you at least have a set of Chucks poly motor mounts.  You'll want to buy a set of control arms also.  Trans-brake really isn't worth it unless you're racing it regularly...competitively.
AOD or C4 or C6
where is a good place i could buy 31 spline axles and c-clip eliminators?
AOD or C4 or C6
Jeg's, Summit, many of the vendors listed in MM&FF also carry them...if you have a T/C rear, you may be screwed...I don't think they make c-clip eliminators to work on the 8.8 with disc brakes...if you still have the 7.5...well...throw that in the dumpster and find yourself a nice 8.8 with 10" drums from a fox body mustang...direct bolt in.
Good luck,
Don
