Topic: V6 to 4 Turbo..... (Read 3639 times) previous topic - next topic
V6 to 4 Turbo.....
Since my car its not running, i was visiting a lot of junkyards. i have seen a good 2.3 Turbo in one, and the price is good. Yeah, i dont have the money for a swap, but i was wondering if the 4 Cyl swap is possible for a V6 cougar-Tbird.....
1985 Mercury Cougar V6
1989 F-200 V8
1996 Explorer V6
2001 F-150
Re: V6 to 4 Turbo.....
of course it's possible, the 84-86 cougar XR7's had the 2.3 Turbo, same with the t-bird Turbo Coupes.
a turbo 4 would probably be a failry easy swap if you were to go carbed and a manual trans.
Quote from: Haystack
Carbed HUH??? Lets see, you'd need a different intake and distributor. Then Have to figure out how to plumb the boost from the carb to the turbo then into the intake(or build a pressure chamber for the carb if it was a blow through system). So hows all this easier than connecting a few wires, and using the original EFI??
That's kinda what I was thinking.  Shouldn't be any harder than going to the 5.0 HO.
With an engine/trans/ECU and harness it would be pretty easy.
My 83 was originally a 5.0/AOD car (then a 5.0/4spd car) before I swapped the 2.3T/5spd.
Not a big deal......
Even if your car is carbed to begin with, the EFI swap would be much more rewarding than attepting to use the old factory draw-through carbed turbo set-up.
Shouldn't be to difficult. I beleive I may be doing the same thing,if I cant get my 3.8 running again. I have everything for it I have. I tore apart two TC's
:birdsmily: Nate Wenck
Carroll IA
nwenck@msn.com
07 Suzuki Boulevard C50T
2003 Ford F-150 Supercrew
