Topic: passanger side h pipe and o2 sensor removal (Read 1275 times) previous topic - next topic
How in the hell do you get that o2 sensor out! Anyone have some tips/tricks for getting the sensor out, or getting at the bolts to get the h pipe out?
fix the fuel lines 1st. ;)
1979 Ford Fairmont
[/B]
Quote from: 32VFoxBird;188369
the new fuel lines are laying there on the ground next to the car, they are next. I just put in my new power steering rack, and i needed the h pipe out of the way to access the steering shaft. I just got the drivers side off, and put my new h pipe on the drivers side.
cool, man! get back to work!
1979 Ford Fairmont
[/B]
Went and bought the tool, and tried to get the car to start to check for leaks in the power steering. No dice, stupid battery finally ped out, so now I have to buy a new one. O and I found another brake line leak, but this line is the one that comes from the master down the k member area. Its gonna SUCK replacing it, but its better to find it now then when I'm driving down the road...
That Mark VII would sure make a good parts car for a T-Bird.
NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
Its turning into a bigger project then I wanted, but I will have another. I already am saving for a southern one to swap all the parts into.
Plus the 5.0 leaks massive oil and its leaking coolant. Needs V/c gaskets, and I believe a water pump.
sounds like $500 was waaaaaaaaaaaaay too much for that car. good luck with it though.
btw, did you get the new fuel lines on?
1979 Ford Fairmont
[/B]
Yea well its only got 95k on it. It just sat for so long... I will make it good enough to get me around.
no they are waiting. I got frustrated cause its been up like that for weeks and I wanted it done so I threw the wheels back on and stuck it on the ground.
