Topic: The Truth About Motorcraft Products..... (Read 4073 times) previous topic - next topic
I think what was meant by Fords specs, applies to the quality of the materials used in the construction, and construction method. Take differential gears as an example, last I heard all factory Ford differential gears are fully hardened (all the way through the gear), while quite a bit of aftermarket gearsets were only case hardened.
As I stand by my previous statements...
Just because they are produced in the same factory on the same line, does not mean they are identical parts.
Just because 2 items crossover to the same application does not mean they are the same.
I'm still going to have side with the MANUFACTURER on this one. I'd believe Honeywell telling me they're the same part, because they make them BOTH.
Some ad head at Motorcraft trying to drum up sales is going to do the SAME thing every other salesman does, tout his own companies product and make claims.
Sorry, but Honeywell says they're the same except for the ink, the ordering is the same less the ink, the heat ranges are the same less the ink.
I don't buy the sales BS.
Call the guy on the production line and ask HIM, not some corporate suit.
This is also why when you buy an American Chisel It is Black because it is hardened. When you buy a Chinese Chisel it is black because it is Painted ! But they are dimensionally the same.
1985 Thunderbird TC
2.3l .03 over,Ported and polished Head and E6 Manifold, LA3, T3/T4 Hybrid Turbo, Stinger FMIC, Forge BOV, Full 3" Exhaust, Essy Timing Gears & UDP's, BBK 255lph Fuel Pump, Kirban AFPR, Kirban Short Shifter, K&N Cone, Forced4 VC Vent Kit, PA Performance 3g Alternator, Energy Suspension Bushings throughout, CHE LCA's, SFC's [/LEFT]
i couldnt give two shiznits less who makes what parts. ive tried all kinds of parts. motorcraft plugs and wires work best on my motor. period.
Quote from: aBM
i doubt line workers answer the phones.
what makes you think the guy from honeywell isnt tryin too boost sales of the other brand names by tellin you they are built to the exact same specs as OEM??
Do you believe the "Tornado" actually saves fuel? Or that you can slap a magnet on a fuel line to "align the molecules"? Come on, open your eyes and really look.
Honeywell makes more profit selling Motorcrafts then it does on it's own Autolite brand. Why on earth would they try to get you to buy the Autolite branded stuff? Answer - they're NOT. The parts are the SAME.
Believe what you want, but it seems the slick sales guy can still fool people. *sigh*
And none of this matters to me as I wouldn't touch either plug or set of wires for any car I own, resale or not. NGK's and Magnecor's here, have been for almost a decade, including my old SHO...
Quote from: Aerobird Motorsports;188245
my point exactly. a lot of people believe the OEM parts are too expensive. so, tell them all that the other brands are exactly the same and make the profits in quantity vs. quality.
sounds pretty simple to me.
Quote from: Cad-T-Bird 500;188146
My co-worker has a 1996 Ranger pick-up with the original battery.  The other day he came in and said the battery finally gave out.  Turned out the battery cable was bad and the battery was still good.  The battery out lasted the cables.
Go Motorcraft!
TED
same with my brothers 94 f-150  original alt as well. but he did "cheat" and replace the regulator.  but it's a no option truck . not even a/c and it's a 300 I 6 5-speed. shorty bed.  but has the beer can window lol
Go Motorcraft!
TED
I've had the best luck with motorcraft batteries.  The one i'm running right now was made in 2001.
Is there a manufacture date on motorcraft batteries?
Quote from: bhazard;188316
:dunno:
I pulled it from a wrecked '01 windstar in 2002.  I gotten my $10 out of it.
colored dot sticker on them with month/year.....
and again, everyone can buy whatever brand they think is the best, i'm not bothered by it.  but i have years of experience with Motorcraft brand vs. aftermarket.  i'm here to tell you, you wont find anything as reliable as Motorcraft.  sure the parts store will warranty the others, but how many times are u going to replace the other brand vs. once for the
Motorcraft.  i will GUARANTEE u, regardless of what youve heard, all parts are NOT created equal.  just because the same company makes the on the same line does not mean the components r the same.  so belive what u want.......
