Topic: what spark plugs should i get? (Read 5192 times) previous topic - next topic
Except Autolite makes 100% of Motorcraft plugs...
And yes, they do sell them for less. The higher price of Motorcraft is just for the "name". This is why it's not "advertised" outside of trade publications and vendors.
Quote from: Aerobird Motorsports;188081
Except Autolite makes 100% of Motorcraft plugs....
as stated by whom???  i have testament that China Spark Plug Manufacturer  has a contract with Ford to make Motorcraft plugs also....AND without any specs or performance proof to back it up,  you'll have a hard time convinceing me otherwise.  i've been doing Ford parts for over 15 years and just like "my car is faster than yours", until you show me proof, its hearsay....  PLEASE SEE THREAD IN GENERAL 'BIRD/COUGAR FORUM......
I dunno I put Autolites in or Motorcrafts and the car runs exactly the same :hick:
um i have a question. 32VFOXBIRD told me that NGK's TR55-1 fits my head, but the only ones i can find are the TR55IX iranium that cost $6 a plug. will these work?
Order the standard TR55-1's. The platinums will fail quickly under any sort of out-of-tune from the motor.
where else can i buy those at?
NAPA, CSK, Schuck's, AutoZone, CarQuest, Baxter's, etc.
NGK's may be great in the 2.3's, but I've tried them in both SO and HO 5.0's and strongly dislike them...I run autolite 25's in HO applications and they are the best I've tried yet...In the summer months (above 60*), you can run autolite AR133's and you'll feel a seat of the pants difference in an HO....not to mention you can order them from Advance Auto for like $21 for a set of 8.  There is a reason my old 'Bird ran 14.30's with a stone stock HO, speed density ECU, and an AOD into a 20+ mph headwind.  My trap speed on those runs were showing that I had the power to run faster too.
For the track, I wouldn't run anything other than AR133's or modified Autolite 24's.  Some guys have claimed 20hp improvements on an engine dyno with the AR133's, I can't vouch for the accuracy of that, but you can definitely feel it.
my 5.0 HO runs so much better now that I got the ford racing wires, and NGK's as told to by aero. It smoothed out the idle, throttle response increased, and thats with a low fuel pressure because of leaky fuel lines.
Reply #39
NGK's, period.
Glad you like them boss ;)
Reply #40
Quote from: daboss351;188281
if you have old py plugs and wires on there and do a tune-up, regardless of brand, it will smooth out the idle and run better. NAPA, motorcraft, ngk, whatever it is, it will work better then worn out ones.
1988 Thunderbird sport
2004 Ford F150 Lariat
2008  Chevrolet Cobalt Sport
1988 Thunderbird LX - sold
Reply #41
i got Bosch right now but i am switch to NGK TR6s to go with my Supercharger. if you lived anywhere close to me you can have my Bosch spark plugs for FREE they work ok but got i think around 9,000 miles on them.
Reply #42
Boss, did you get the 9mm blue ford racing spark plug wires?
ok, thanks for the info!
Reply #43
Yep I sure did! Awesome product, perfect fit, all the connections came pre greased, no little packet of grease. Well worth it! They look good too.
Reply #44
The 9mm plug wires are not bad for the price and work well.
