Topic: More pics of my 86' (Read 5376 times) previous topic - next topic
More pics of my 86'
Very interested in the DOHC swap keep us updated
2004 Impala
More pics of my 86'
Quote from: 1BadBird;187766
Future home of 4.6 DOHC w/5spd. That is of course after the area is free from excess holes and painted
I was trying to see if I could get rid of some holes, but a stick welder isn't good at doing that.  I keep making the holes bigger :hick:
More pics of my 86'
LOL, Ya that tends to happen when using stick welders.
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
More pics of my 86'
God I love those wheels....
More pics of my 86'
still planning on using that hair dryer?
1979 Ford Fairmont
[/B]
More pics of my 86'
Filling in the holes is pretty easy I saw this trick on TV he used a rod that was like half copper and bronze I think and just used a torch, in this case a MIG torch lol.  But i have done it with an oxy acetylene torch.  You could probibly get more info on powerblocktv.com Lou on the Muscle car show did it to fix some swiss cheese on that le mans he's restoring.  I have also head of people using a copper disc with a rod welded to it, for manuverability with welding gloves on, and just putting the disc on the back side of where you're welding the puddle wont stick to the copper so you can fill it in pretty nicely, seen it done but never tried it, also i'm not sure if it was copper but i think so.
2004 Impala
More pics of my 86'
Quote from: 32VFoxBird;187908
Eventually I'll use it. I'll need to gather the related parts for it and build the engine to handle it. But the way I'm draggin :shakeass:  on the whole project, it'll probably be a long time before that happens.
capitlj, I have a Dent-fix that I'll use to weld studs to the pieces of sheet metal so I can hold them in place while I weld 'em in.  But thanks for the tip anyway, ya, I saw that show too. God I'd love to have that kind of unlimited budget and that much work space :evilgrin: Then to work next to that little blonde that does the extreme 4X4 show :evilgrin:  (shame on me)
86' T/C 4.6L DOHC
[/COLOR][/SIZE]
More pics of my 86'
Ahem!!
You have a PM bad bird
More pics of my 86'
would lead be a good filler for the holes?
More pics of my 86'
daboss351, I returned your pm :D  I'm not on my own puter right now. It's my friends :D
Chooglin, I wouldn't personally use lead, there's other stuff on the market, and some stuff I have, that will work just as well if not better than lead. The stuff I have can be drilled and tapped. I just need to quit draggin:shakeass:  and get my house completly finished so I don't have the better half (?) on my:shakeass:  :evilgrin:
86' T/C 4.6L DOHC
[/COLOR][/SIZE]
More pics of my 86'
Use a penny clamped in a pair of needle nose pliers on the back side, then just go around the edges of the holes with small tacks til it is filled.  Then clean of the weld with a wire brush and fille the backside with weld, then grind off.  done.
More pics of my 86'
Quote from: 1BadBird;188036
Jesse Combs is soo hot she's from my neighboring state to the south too.  I'd give my right arm to work with those guys even as a parts bitch.
2004 Impala
More pics of my 86'
mind if i use one of these pics for the calendar?
More pics of my 86'
Go right ahead :D Thanks, I'm blushing.
Uhhh, which one if I may ask????????
86' T/C 4.6L DOHC
[/COLOR][/SIZE]
More pics of my 86'
The side shot with the Starion wheels.
