Topic: What In The World Is Going on with my seats..... (Read 962 times) previous topic - next topic
alright thought my power seats were froze so i took seat out greased track everything greased back up right tested track before i put back in car with batt charger it moved good fowards and backwards up down side side all works i hook switch back up it dont work fuse isnt blown get 12V on all ways of movement of the seat .......what is going on with this stupid power seat it all started when the thing was all messing up would move alittle then quit so i thought it was switch switch was nasty as hell anyways..that dident help so i thought track was screwd...i havent replaced harness think thats best bet or what?
I tell you to get out the meter and test the leads where they plug into the seat. If the seat works when you put power & ground to is then it should work in the car unless there isn't a good connection between the seat and all the electrical switches and fuses.
thats the thing correct voltage at plug that goes into motor connection
my dad mentioned something about fords seat motors that they can spin all the way around and work backwards of the way the switch works or something.....
