Topic: CFI to SEFI ver.238412412873412783 (Read 3427 times) previous topic - next topic
Quote from: Drewstang;191846
Thats a very good point I did not think of. I'm going to be using a 94-95 5.0 HO so I guess I need to track down a 86 GT/ LX 5.0 ECU.
No, you'll need a Mass Air EEC to run an engine newer than 89.
An 86 was still Speed Density.
Unless of course you change your engine back to SD, that is.
Yeah, I was going to run SD until I got the money to do the MAF conversion with Mustang A9P ECU.
So, to be 100% clear I can run the 94-95 HO with the 86 T-bird ECU so long as it stays speed density correct?
sure can, i might have a  87-88 mustang ecu, i will check for ya
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
sure did on friday, will go out today!  did you want me to see if i had the h.o. computer and swap it for the s.o.?
