Topic: head-rockers combo problem (Read 2430 times) previous topic - next topic
Flat-tops without valve reliefs and 2.02"/1.6" valves = pwned except Twisted Wedge heads.
More info on them here:  http://www.corral.net/forums/showthread.php?t=565955&page=1
Be wary
well, i bolt up a side and checked clearances...sorta. i think ill need longer puchrods, the stock length ones will work, but i couldnt bolt the rockers down all the way, only because i didnt have a deep enough chrome socket and my deep impacts were too thick couldnt go down into the rocker where the nut is. there was very little lash in the rockers, but still some lash nonetheless. the clay read a minimum of 5/32 (.156). the specs said a minum of .08 was required. so i have a .076 extra. so im gonna try to find pushrods about a 1/2 longer and see what the clay reads then, but so far so good. so whats the length of stock pushrods?
1988 Thunderbird sport
2004 Ford F150 Lariat
2008  Chevrolet Cobalt Sport
1988 Thunderbird LX - sold
Your clearance might be lower when you get the proper pushrods.....
yea, im affraid of this. im ordering the adjustable pushrod tool. if this does work... its just barely gonna work. but hey, if it does  people have a new option for heads.
cross my fingers and pray to the Lord,
dont let me down, you f***ed up Ford
update- got the pushrods checkers in, i need a 6-9/16 (6.562) inch pushrod. GOOD NEWS, it appears as though these heads are going to work. the clay read 3/32 (.0937) which is still better then the .08 needed to work properly! we wont 100% know for sure untill its all back together and i try to fire it, but things are within spec. anyone know where i can find a 6.562 inch pushrod? i looked at jegs, everything seems to be 6.8 or 6.2, not much in the middle.
anybody know where i can find 6.56 pushrods? the closest i've found is 6.40,  where it says 'one piece; no' i dont know what that means? if no one knows of any closer to the size i'm looking for, i might try these, but will a non-one piece work properly in our cars?
Call up Summit.  They can get the size you need.
