Topic: Hood latch broken (Read 1564 times) previous topic - next topic
Hood latch broken
How do I go about opening my hood when the latch has broken? I pulled on the release cable and nothing happened. Need to get my hood open. Any help is greatly appreciated.
1987 Thunderbird 3.8. Sold :(
Re: Hood latch broken
what year car do you have? and is a TBird or Cougar?  is the cable busted or is it the latch it self?
It's an '87 TBird.  I think the cable came out of the latch because half of it was broken.  It used to stick open because the spring was broken and I'd take a hammer and flathead screwdriver to pound it back so it would latch again when I closed the hood.  Half of the metal part that holds the end of the cable broke off at one point and I never replaced the latch.  I have one and was going to do it this weekend, but I guess I was too late
look from under the car , if any cable remains grab it with pliers or something and pull.  if not try and unbolt it or undo it based on what you see.
