Topic: 3.8L Starting Issue (Read 2780 times) previous topic - next topic
3.8L Starting Issue
jcassity--are there codes listed in your diy fix it link?
sorry, i found it in the tech library of the ranger page there's a lot of good stuff there
Ics
Hello all,
      Here's a thought about the ICS motor, I had to do this on my 87 Cougar LS 3.8.  Reset the ICS motor.  The procedure is within the shop manual; it involves a small jumper wire to connect the self-test terminal to another terminal on the self-test; once a connection is made, the ICS will retract, allowing a new 'ground zero'.  Perhaps after the 'arching' effect you discribed has disrupted the ICS motor, resetting it may just solve it.
If you don't know how to do this; or don't have the book, I can look it up for you and post it up here.
Operation: X Marks the Spot
5.0L SEFI, AOD, 8.8" 3.02 TracLok - All Stock
