350hp!!
Reply #43 –
Sounds like a kick a$$ street setup. The Edelbrock Torquer 2 has high dyno runs. Check how it specs at Andersonfordmotorsports. 70-75mm throttle body and a 90mm lightning mass air. 42lb. injectors and a pms standalone running the electronics.
For the transmission, ditch the lockup converter for a nonlock from Precision Industries or Dirtydog they can help with the stall, install a baumann shift kit and a transgo high rev governor. The transmission should be overhauled and modified. Check our clickclickracing.com. Or if you have to have lockup, ditch the aod for a 4r70w with a manual valve body and lock the converter with a 12 volt switch. It's like having another extra gear!
Out back you'll need some drag radials with a 31 spline traction lock differential with 31 spline axles. . You could go with a 4.10 gear if you really want to move it quick. Also you may want to try a narrower Mustang rear end which would allow you to stuff the largest drag radial you can between the fenders. You'll need it especially if you run the juice on top of that combo. :evilgrin:
Keep us posted. Sound like it will be a mean machine
Mike
