350hp!!
Reply #29 –
i cant get a 351 because my dad wants to get the stock engine block to keep matching numbers ( we are keeping all stock parts in garage)
so do you guys think i should get a 331 stroker kit with AFR 185's heads with a comp cam fwnx264hr14? what intake manifold should i get? i'll also pick up a pair of roller rockers. would a 3000 stall be ok?
this is what my brother has in his GTP
Rebuilt Engine, Custom Cam, 3.22 MPS Pulley - 1.9's modded rockers- Custom Intense PCM- 72mm ZZP TB- W-body Shift Kit- PEM'S in to a 3" Down pipe- ZZP TB SPacer- Autolights 104's- Wizard CAI- 9" K&N Cone- Flowmaster Cat-back-180* T-Stat- U-bend and Res. delete- Dual Aeroforce scan gauges- airfuel gauge- Traction T/A 235/60/16.
