Topic: ProForm Roller Rockers JUNK? Pictures inside (Read 3993 times) previous topic - next topic
These two different rockers came in one box for Johns project Goldmember.  12 are the design on the left and came in a bag.  4 are the design on the right and came in a box.
The one on the left looks as if its not fully machined.  There is a ridge in the cup that would grind the top of a pushrod if this was installed.
Looking at them.. the one on the right has the pushrod cup closer to the fulcrum of the rocker than the one on the left.  :mad:
What gives?
the left one looks like a 1.6:1 and the right one looks like a 1.7:1
louie  :birdsmily:
My famous last words:
ALL ProForm stuff is .
That is FACT and not opinion.
They got their @$$es handed to them by MSD in Federal Court last year and the stories get worse from there. There are currently three lawsuits in motion by other companies for copyright fraud.
They have THE worst return rate of any manufacturer for both defects AND fitment (as in the stuff doesn't fit).
I won't touch ANYTHING they make with a 10' pole. Neither will any of my distributors. Summit/Jeg's/ProForm direct/and local shops (think NAPA esque) is the only way to get their  anymore. All of the major dealer/distributor/warehouse networks have dropped them.
Send them back and buy some good rockers. Scorpion's are great for the $$.
Quote from: Aerobird Motorsports;184432
They make nice carb main bodies:shakeass:
Anyone Have any probelms with the Crane 1.7 roller Rockers?
http://www.steeda.com/products/crane_cobra_roller_rocker_arms.php
If i rebuild my engine later on has anyone tired the Steeda 1.6 Rockers?
http://www.steeda.com/products/steeda_aluminum_roller_rocker_arms.php
your thinking of PRO COMP not pro form. two completely different companys.
86 thunderbird elan
86 mustang coupe
fordguy,
! You're right, I'm thinking of Procomp! Stupid names are too close :hick:
"MSD OBTAINS FEDERAL INJUNCTION AGAINST PROCOMP ELECTRONICS
El Paso, TX-based MSD Ignition/Autotronic Controls Corp. has obtained a permanent federal injunction barring Procomp Electronics of Ontario, CA, from offering ignition products that uses a design confusingly similar to that used by MSD.
This all stems from a lawsuit Autotronic filed against Procomp in U.S. District Court earlier this year, where Autotronic claimed that Procomp intentionally used an infringing design. Autotronic alleged that a Procomp product uses a design essentially identical to the shape and color of Autotronic’s ignition boxes. It also claims that Procomp’s product also bears labels that use a design that is confusingly-similar to the design used by Autotronic.
Autotronic said it was being harmed by these actions and asked the court for an injunction against Procomp’s continued use of this allegedly-infringing design. It also asked for all of Procomp’s profits from selling the product in question. The two companies recently reached a settlement that included the injunction mentioned above. Procomp has agreed to cease using the design in question. The injunction was issued in order to ensure that the agreement is fully enforceable by Autotronic."
http://www.camaroz28.com/forums/showthread.php?t=363139&highlight=pro-form+rockers
"Anyone ever used these things? I just got some in the mail new and they are trash. I can feel the play in the tip just by wiggling them. its almost like theres no bearings in them. I should have kept my 1.6 nsa.Anyone else see this problem?"
"from what i have seen, all of the pro-form products are made very cheap"
"I have heard multiple stories of people having problems with the Proform RR's. I have a friend that bought a car w/ these proforms on it. I have a pic somewhere of how they break. They are a poor product."
http://www.allfordmustangs.com/forums/5-0l-tech/6075-broken-1-7-rocker-seats.html
"Does anyone know any info about Proform? As in do they have a wbesite? I got some profrom rockers and some seats broke. I need to get in contact with them. Thanks."
http://www.allfordmustangs.com/forums/mustang-tech/88755-blow-troubles-1989-mustang-gt.html
"Oh and one more thing... one of my roller tips on my rockers (Proform full rockers) split in half."
To be fair...
The same forums also have about the same # of threads saying good things about ProForm rockers. Seems like they are ProForm's worst item, and run about 50/50 on working. Looks like most of their stuff is pretty good.
I'd personally still step up to a better rocker. Good ones really aren't that much more.
I just purchased the 7 qt oil pan and let me say that it was a piece of .The pan had metal chunks in it burs on the parts where they cut open the pan, and it did not clear the stock oil pump or did it fit on the block.I had to hammer the spit out of it so it would fit with their pick up.Then when I let the motor down the pan hit the rack so had to finesse the metal some more.
TOTAL shiznit!!!!!!But great price compared to others.
I also have their knock off black magic fan and it works great over 5 years old.
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
"Proform" just looks like cheap junk even in the catalog.
I have to wonder if the tools they sell under that name are any good.
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
*cough*Jesel*cough*  Last rockers you'll ever buy.
$1k rockers for $138 rebuilt heads?  Laughing Out Loud!
Claude,
Try Crane. They're actually cheaper then the ProForms!
http://store.summitracing.com/partdetail.asp?part=CRN%2D44746%2D16&autoview=sku
Or the Scorpions, I know from experience that these are awesome rockers:
http://cgi.ebay.com/ebaymotors/SCORPION-PERFORMANCE-SBF-1-6-ROLLER-ROCKER-ARMS_W0QQcmdZViewItemQQcategoryZ33624QQihZ011QQitemZ320172082823QQrdZ1QQsspagenameZWDVW
The cheap cranes are 1.7's, we need to stay at 1.6.
Johns thinking about the scorpions.
I have scorpion 1.72s and I highly recomend them. They are a little noisy, but the quality seems really good.
~1988 thunderbird~
In hibernation, waiting for spring.
