Topic: Mach 1 springs in the rear - pics! (Read 7805 times) previous topic - next topic
Why does everyone on here seem to favor CHE arms of MM arms?  Is there something I'm missing (besides the price)?  And why don't I see arms with adjustable spring perches on there website?  Oh yeah, and do the CHE arms do anything for quad shock removal like MM claims theirs do?
1988 Thunderbird Turbo Coupe
Theres a pic on this page.
http://www.cheperformance.com/cartgenie/prodList.asp?scat=30
I bought them for price "coolcat discount"and were recommended by others.
- Half the price
- not forced to use a harsh rod-end on one end
- MM says "The Heavy-Duty arms are suitable for cars with moderate horsepower levels that are not drag raced."
They don't make an "extreme duty" (drag race capable) for the Fox Bird/Cougar
Oh, and I removed my quad-shocks with the CHE arms and saw no wheel-hop at all using M/T drag radials that were dead-hooking.
Sweet!  So, i was looking at this link.  It shows the height adjustable ones but doesnt say what car there work on.  Then, above to the left is the NON height adjustable version for the tbird/cougar.  Just curious what the difference is...
Ok, so if I buy them, what quanity do I enter?  I would assume they sell it in pairs, but then again why would it even ask quanity?!?  My luck, I'd either end up with 1 or 4!!
Quote from: Cougar5.0;199984
The use of a spherical bearing results in less bind than poly in both ends, which is good for cornering.
From what I've read, the spherical bearings aren't much worse than poly.
Quote from: JeremyB;200018
I agree that the spherical will bind less (essentially none) in cornering. For me it was especially noticeable when I had the car jacked up in the back and stock height in the front. I had quite a bit of "push" (understeer) in the corners that was unpleasant. The fact that I removed the front sway-bar for drag-racing was a part of this as well.  Pushing it hard could lead to "snap" oversteer (hard bind) which was even more unpleasant. Now, with the stiffer Mach1 springs all around and the car being lowered, the steering is like being on rails - the feel is outstanding and very neutral. I can now do refined steering adjustments even in hard turns. I assume that the higher spring rate in the rear matches up better with the stiffer bushings keeping the rate more linear through the typical travel range of the suspension. What do you think?
I am looking into a set.
Of what, the CHE's?
Reply #39
Do yourself a favour and don't get the adjustables. I bought 'em thinking that more expensive = better, but now I regret it because I've got a severe case of "sky butt". The adjustables add at least an inch of height (with stock TC springs), and combined with my lowered front (stock TC springs in a V8 car) my car looks ridiculous. The only good thing about 'em is that they allow you to use the Mach 1 springs as this thread shows...
Oh, and in case you're wondering, this is what I mean by "sky butt" (this pic was taken before the front spring broke):
Reply #40
LOL...  Well, I plan on running Mach 1 springs.  And since I have full adjustability in the front with the coil-overs I want some adjustability in the rear.
