Topic: tire/wheel combos (Read 3174 times) previous topic - next topic
tire/wheel combos
whats the thinnest and the widest tire you can SAFELY run on a 7'', 8'' and 9'' inch wide rim?
1988 Thunderbird sport
2004 Ford F150 Lariat
2008  Chevrolet Cobalt Sport
1988 Thunderbird LX - sold
what width you can run partly depends on sidewall height
Generally speaking, a taller profile gives you more size choices.  A 245 60/15 works on a 7" rim better than a 50 series of the same width.
What were you thinking about running?
__________________
Twin '85 TCs
White/ Grey 2-tone
tire/wheel combos
well, i found these that come with tires
http://cgi.ebay.com/ebaymotors/17-Mustang-Cobra-R-Wheels-Rims-255-ZR-Tires-79-93_W0QQitemZ290171907846QQihZ019QQcategoryZ66483QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
but will a 9 inch wide wheel be O.K. on our cars without rubbing?
theres the 8'' front, 9'' rear package,  i think 8'' are ok on the front, but i'll have to buy my own tires, and idk what sizes are the best to run.
http://cgi.ebay.com/ebaymotors/17-8-9-Silver-Mustang-Cobra-Rivet-Wheels-Rims-79-93_W0QQitemZ290172240177QQihZ019QQcategoryZ43957QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
but if 9'' will work o.k. on thr front, i think ill just opt for the 9'' and tire package.
tire/wheel combos
Up front, I don't think 9" will fit without changing something that isn't easy to change.  With std. offset, the tire will protrude past the front wheel arch.  You might try '05 Mustang offset (+42mm?), not sure if they will clear the struts.
255's might work, since 245's will.  Keep in mind, lowering the front 1+", 245 60/15's will rub the top of the fender liner during spirited driving.
Back in the day, SVO said the max sizes were 245's on 8" wheels up front, 275's on 9" wheels out back.
__________________
Twin '85 TCs
White/ Grey 2-tone
tire/wheel combos
great, so i guess i gotta go, 245/40r17 on an 8'' up front, kinda sucks cus that 9'' wide with tires is a pretty good deal. i cant see any practicallity in going anything wider then 255 on the back with the power i'll be making. thanks for all your help. looks like i got some more shopping around to do...
tire/wheel combos
I have the 17x9's all around,with 245's up front and 25's out back.I had to add a 1/8 spacer so the tires wouldn't rub the struts.I will eventually install 17x8's up front.
tire/wheel combos
Can I maybe see a picture of that?  I am in the market for wheels, as due to my lack thereof, my TC is off the road...
tire/wheel combos
I have 245/50/16 on 7 inch wide snowflake rims and it works fine.
I also have 275/60/15 on 8 inch rims and this works great also.
I tried to run 10.5x28x15 slicks on a 7 inch 10 hole and this did not work at all, this is about a 275 tire.  Too much curve and I lost traction, also looked kind of funny.
TED
tire/wheel combos
Quote from: Cad-T-Bird 500;187744
TED
you didnt have any problems with the 245's?  i have ponies and i need tires again so i was going to go up to 245/ 50's but when i got my tire i have now they said it might buldge/ curve the tread too much and wear wrong.
tire/wheel combos
I run 245/50's on my gray car. No problems
....especially now since the car is on stands...and half the parts are in the yard...
tire/wheel combos
I posted this once before, but will add this again. Goodyear used to recommend 205-7", 225-8", and I would assume 245-9". Many Fox Mustangs came with 225-60-15s on 8" wheels. I tried a set of free 245-50-16" Gatorbacks on the rear on 8" Enkies, and they felt "squirmy" compared to the 225s. And they wore in the middle, not evenly across. 20mm is not exactly one inch, I know. But this size-area was where the info applied. I have seen roadracers use 275s on 10"s, and 315-325s on 12"s. RR guys want the minumum amount of sidewall flex, so the size/width ratio is followed pretty closely.
This would be optimum for the street, but not written in stone.
tire/wheel combos
Quote from: Prototype Services;188021
they wore in the middle, not evenly across. QUOTE]
thats what i was wondering. my tires are 1 year old now an im replacing them... not doing that again next year.
