Topic: Try This (Read 3574 times) previous topic - next topic
Try This
I don't understand the problems with question 7. That’s one I found easy NOT being able to figure out the "reverse" part. I just skipped "Reverse", and was a no brainer from there, simple process of elimination..
Direct is obviously C
Reduction is obviously A
Overdrive is obviously B
Reverse can ONLY be D... I didn’t understand WHY that one was reverse but it just had to be.
19 was one that gave me trouble
Try This
Quote from: Jim_Miller;182644
Because "A" reverses the driven gears rotation from it's own and "D" reduces the drive ratio - that's why!
Try This
Yeah, I got to #7, saw the ambiguous nature of it..and quit taking the test.
Try This
Quote from: JeremyB;182648
cooch.
:laughing: :slap: :nkhk:
Just kidding ;)
Try This
I suppose I am what I eat. :hick:
What does lazy taste like?
Try This
On diagrams A,B, and C; the driven gear rotates in the opposite direction of the drive gear giving a "forward" momentum.  With the extra cog between the 2 in Diagram D, the driven and drive gears rotate in the same "reverse" direction.
Try This
Dooohhhhh !!! 80% :(
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
Try This
i got a 78.  , i'm a moron.
87 thunderbird turbocoupe
06 pontiac g6 gt
:birdsmily:
Try This
I apparently missed most of the questions on lifting pulleys. I was under the impression that each pulley reduced the load by 50%. High school was too  long ago. :(
I did get the two "stable/unstable" right.:rolleyes:
Try This
The answer to #31 is 60 kg. Hmm, where do I put that...
Try This
 a 78%
louie  :birdsmily:
My famous last words:
Try This
76%. I'm stupid...
Try This
Wow im the dumbest a$$ on here.. I got a 58%. In my defense I was working while I took the test trying to read questions while talking to customers on the phone. No excuse I guess but I feel like a "ASS HAT" Thank you thunderjet...
:ford::oldcougar::mercury:
Try This
Quote from: JeremyB;183012
Interesting - you counted the "spaces" and came up with a 5:1 ratio.
Try This
No, the correct answer is 100
300*1=X*3
X=100
edit: i counted each dash as half a unit of measure
they could have illustrated the problem better
