Topic: need advice on fuel injection upgrade (Read 867 times) previous topic - next topic
just got a 91 town car to s is there any thing i can use on my vert before i junk it ill prob get the fuel injection stuff off to convert from my tbi also would the roller heads make any difrence on my 85 tbi...should i use every thing from the heads up or should i just use just  the intake and stuff ....can i use the computer and fuel injection harness please a little help here also can i use any of the brack parts and the axels for five lug swap
Is this a 5.0?
Yes
Use the heads you have.  THe Towncar Fuel injection system is of the SO variety (read: 14 pound injectors).  Take the intake, rails, and EVERY stitch of wiring harness and sensors and of course the throtle body and air tube.  Your current cam will have the same firing order as the Town Car cam except the Town car cam is a roller cam.  You can use the injectors and computer from the Town Car if you just want to get the EFI up and running, but don't expect a monstrous increase in power (if any).
the wiring harness isnt a "bolt-in" for fox cars. the computer is mounted on the driver side underneath the dash by the brake pedal. i tried using that harness years ago, but it was too much work.
1979 Ford Fairmont
[/B]
You already have better heads, the '86-up SO 5.0 uses the infamous E6s...
None of those parts are good for making power...
