Topic: Like dyno graphs? (Read 2442 times) previous topic - next topic
Like dyno graphs?
An auto will show lower dyno results, but not THAT much lower.....Mustang dynos typically show lower results than a Dynojet would as well.  What cam is in that thing?  I know you say it's the same as an HO, but what year?
Like dyno graphs?
Even if your shifter was in O/D the transmission should not have actually shifted into overdrive on a dyno unless he was going like 100+ mph unless your TV cable is fubared out of a adjustment.
Like dyno graphs?
Quote from: sum_weirdo;181165
Keep in mind it's not a manual transmission.  The dyno guy's been doing this day in, day out for years, I have to believe he knew what he was doing even if I don't know how he did the math.
Yes, a good condition AOD will have around 20% parasitic loss.
Like dyno graphs?
Okay the dyno guy finally replied to my email and this is what he said:
"The tests were run in 3rd as second cannot be manually selected on your car. The conversion I use for SAE net is as follows:
((Wheel HP) + (auto trans loss)) / 0.75
(159+25)/.75 = 245.3 HP SAE Net."
I'm not sitting behind the wheel at the moment but I don't remember my car having an option for 3rd.  And anyway my gear ratio graph has 3rd as the 1:1 gear not 0.75:1.  Guess I gave the guy too much credit for experience....
Oh well.  I kinda had the timing screwed up for that run, I'll probably do better next time.
Like dyno graphs?
Stared at the gear selector a bit on the way home.  Like I thought there's no selection for third gear.  But interestingly enough the 3rd selection up is the Overdrive.  Now I know it's been said that it's doubtful the transmission would shift into Overdrive on hard acceleration but I know it has before during a little street race.  Besides he didn't stab the gas and go to town with it, he ran it in the midrange for a bit before going for broke.  And the overdrive ratio is about right for these results.  Just speculation I guess.
Like dyno graphs?
Not suprisingly, most of this is way over my head... Nice numbers though! lol
