Topic: popping and squeek "SOLVED" (Read 22137 times) previous topic - next topic
Reply #60
Quote from: Chuck W;198542
I never said it was an optimal design.  I said it served a purpose.
this is true
Reply #61
So the bar is not on 3.8 cars??? Has been on all the 2.3T/5.0 Birds I've owned(one '86, other 17 all '87-'88s)...
Reply #62
I've never seen it on a 1983-86 car, but it's possible that the bar made it to Turbo Coupes/turbo XR7's during that period. All the 1988 V8 cars I've owned have had it. Don't recall seeing it on the '88 V6 car.
Reply #63
throw it in the trash and get a 4pt. brace
Reply #64
Quote from: gumby;198590
Yes, but the 4-point Mustang ones don't work.  At least they never did on my cars.
Reply #65
Quote from: Chuck W;198598
booo to that.
make your own! :shakeass:
Reply #66
Quote from: gumby;198600
booo to that.
Oh trust me....I've been contemplating....
Reply #67
I wonder if someone here couldn't fab up a bar that would work around all 3 stock oil pans (2.3 3.8 and 5.0/5.8 ok it's 4 oil pans wth!) and market 'em.
Only thing is...as pointed out already, they'd need to be square tube and at least 2 holes on each end.
Chuck, would this be feasible? I'd sure be interested...
I've kept the one off the TC, but I didn't know if it would work with the V8 that is going into my Bird.
Reply #68
If I did one, I wouldn't waste time with a 2-point.....
Reply #69
Quote from: EricCoolCats;198563
Well maybe I'm mistaken on the '86(was a 5.0)... Didn't keep it long, was gone in a month...
Reply #70
Quote from: TurboCoupe50;198559
that bar was on my 20th 5.0.
The white coug which was a 3.8 did not have that bar and i wonder if anyone with a 3.8 could verify.
while we are on the topic of odd ball ,,,,
lookie what i found on my catylitic......
Reply #71
i can verify that bar is not on my 86 tbird with the 3.8 v6
Reply #72
If removing that bar made your noise go away then you have a K-member that isn't completely tight to the body. There are six bolts that hold the K-Member to the body. Just to verify, I would loosen each bolt (one at a time) and tighten using an air rachet because these bolts are a PITA. Monitor the bolt as it goes into the nut clip to ensure the clip is positioned properly. Some lube on the bolt will also ensure it tightens up properly as well. That bar assists the k-member from flexing to improve handling. Also check over the K-Member and where it mounts to the body for any cracking or rust just to be sure. Hopefully this is helpful information.
Raleigh, NC.
Reply #73
something tells me i need to look at this again.  you were right way back on page one.  The noise was "k memeber" related.  i checked those bolts and they are all tight.
Reply #74
I would loosen them, clean the threads with a wire wheel, lube them, then tighten each one with an impact. One by one. If you just put a socket on them by hand they will probably feel tight but due to debris, corrosion, etc... they will be tight to turn but it's probably not tight to the frame. Hopefully that makes sense. Let us know how you do.
Raleigh, NC.
