Topic: Loose steering Fix? (Read 1893 times) previous topic - next topic
Loose steering Fix?
I just picked my car up and drove it a couple hundred miles home yesterday and it seems that the steering is very loose, anyone else have this problem, whats the best way to correct it?
Re: Loose steering Fix?
First you need to climb under the car and actually see what the problem is.  It could be anything from loose wheel bearings, loose inner and/or outer tie rods, bad alignment, bad ball joints, loose lug nuts, deteriorated steering shaft rag joint or a bad steering rack.
