Topic: Antenna question (Read 1995 times) previous topic - next topic
Antenna question
Do I have to take my fender off to get at my power antena on my 88 Cougar??I need to change the inners the motor still works but the white plastic piece that brings it up is broken..
:ford::oldcougar::mercury:
Antenna question
You have to remove the inner fender liner (jack up car, place jackstand, remove right front wheel, remove fender liner). There's also a small insulation piece buttoned right in front of the power antenna motor. But after removing that you can see and get to everything.
Antenna question
Thanks Eric I thought thats what i might have to do but wanted to ask the experts before I went messin it up.. My lincoln is so easy right in the trunk.
