Topic: My F-100 (Read 17418 times) previous topic - next topic
My F-100
Reply #60
stock axles?
my currie units in my stang take PLENTY of abuse.
My F-100
Reply #61
if it's 2wd, it's quite possible to break a 9" axle.  They are mostly 28 splines.  It's the 4x4's that got 31's.  But still, it take quite a bit to break one.  Sometimes asphalt isn't forgiving, lol.
I should also mention some F100's in the 70's had dana 44's in the rear.
1987 TC
My F-100
Reply #62
Quote from: HAVI;219152
yup its a 28 spline rear:ford:
My F-100
Reply #63
Exactly, it must be a 2wd with 28 splines. I've had a 9" Detroit Locker in my 1969 Torino 428CJ since I bought it in 1978 and it has been perfect. It's a 4.11 and has seen a bazillion trouble free launches in the last 30 years. It's a 31 spline though.
1987 Turbo Coupe - Son's car
1934 Ford - My project car
My F-100
Reply #64
Quote from: FLSTCI71;219168
it is a 2wd
its also heavy
My F-100
Reply #65
get some 31 splines!! Especially the way you drive hahahah!
My F-100
Reply #66
Heck I'd go 35 splines and a detroit locker, or equivalent.  Then really smoke'em!!
Honestly, though, another 4x4 complete axle might be the way to go...typically they cost $100 used.  IIRC, you'll need the wider U-bolt plate to line up with the 4x4 axle pad.  4x4's had 3" wide springs and the 2wd's had 2.5" springs.
You'll end up with a 3.55 gear, too....possibly w/traclock
1987 TC
My F-100
Reply #67
hell my 9 inch is out of a station wagon, joys of it 3 inch wide rear drums, drags the assend of the stang to a stop MUCH faster then stock, my dad had it shortened and custom cut axles put in, with a traclock, and 4.11's. When I drive the car I'm not easy on it, and my dad pushes it, and we cant seem to hurt anything but the t-5! That rear takes everything and anything!
My F-100
Reply #68
http://www.youtube.com/watch?v=pRr7UbRb_-o
pass before the broken axle
My F-100
Reply #69
dont think southern cars dont rust..
this stuff was repaired previous to 1987.
before...
My F-100
Reply #70
during
shaving the stake pockets and emblems while im at it
My F-100
Reply #71
more
My F-100
Reply #72
even more nightmare
My F-100
Reply #73
last few for now
My F-100
Reply #74
It's amazing what you find under the paint, isn't it?
Are you butt welding or lap welding? It was tough to tell in the pics.
It doesn't look like you need a whole lot to fix her up.
