Topic: carbed 3.8 to carbed 302 swap (Read 11432 times) previous topic - next topic
Quote from: screaming306;179360
i got an 84 t-bird that was t.b.i. :
ford did not make tbi systems :hick:  perhaps your bow tie 2.8 has you confussed.
little update on this
I took the motor down to Tennessee and they are ready to machine it.
I need a answer to a few questions about the c5 tranny.
*will the bell housing from my 3.8 bolt up to the 302 and if it wont,wich bell housing do I need to look for that will bolt up to the c5 and the 302?
*will the flex plate from the 3.8 bolt up to the 302 and if it wont,wich flex plate do I need to get to work with the 302 and the c5 tranny?
thanks for any help
I know the bellhousing for a 3.8 and 302 are the same.  However someone else will have to help with the flexplate.
:pics-stfu:
 Project Thread with pics
no..no... the flex plate WILL NOT work. i used a flexplate from a 1990's lincoln town car, actually, any car with a 302 and the early stlye a.o.d. transmission will work. I installed mine, and the holes matched the torque converter on my C-4 . then went to junky yard and bought the nice SMALL starter that comes on the V-6 mustangs anything after 1994. and it also fit the teeth and the block and the bellhousing. i was actually quite surprised.
jcassity, is the 1984 -1986 V-6 t-birds and cats not throttle bodied injected with to fuel injectors sitting on top of the throttle body????? c.f.i. yes.......t.b.i. just describing the style of injection. or maybe i'm wrong. but when you look in manuals, and try to buy one from the parts house they call it t.b.i. ?????  who knows???? great now i'm lost...
thanks guys
Scream,would the starter off of my 3.8 work,if I get the flex plate that you mention?
IIRC pre 83 302s used a flex plate that has a 28.8 oz imbalance. 83 and up 302s used a 50 oz imbalance flex plate.
get a flexplate and balancer for a 1985 and up block. better get the block too. NO the 3.8 old style won't work. but the 3.8 starter for the 3.8 1994 and up mustangs will. the newer style starter is alot smaller and lighter, plus it is a permanant magnet type of starter. i have no problem cranking my bird with it. oh yeah also get the starter wires too for the mustang. as you will see the you will end up with a solinoid on the starter and one on the wall. i will take some pictures of mine tomorrow and post them for you...did you look on my cardomain. i think there are some pictures there of the pieces too. :D
Engine is out
Quote from: thunderjet302;187353
IIRC pre 81 302s used a flex plate that has a 28.8 oz imbalance. 81 and up 302s used a 50 oz imbalance flex plate.
Fixed
engine is pretty much ready to go in.now I need to clean up the engine bay and paint it.
Looks good :D
Where's the Ford blue block and heads? ;)
Quote from: thunderjet302;213734
Looks good :D
well,I almost went with blue, but decided to keep everything black,white and chrome.
engine bay is almost ready.I hope to be dropping the motor in next weekend.
Looking good :D
