Topic: When it rains, it pours.....And now it's a Sun-Shiny Day (Read 3342 times) previous topic - next topic
If you want quiet,install tailpipes.I was running without tails for a couple of months,and the drone was killing me.After I installed the Mustang tails,Nice and quiet,until I mash the gas pedal,then things start to happen.
Everything clears now without issue.  Had to cut the right side tab on the motor mount.  Other than that, after we centered the motor there is plenty of room.
I picked up a set of Borla XR1 center inlet/outlet 2.5" lers.  Should sound nice.  Even without them on I must say it sounds good.  The converter is noticeably looser than the one I took out.  I wasn't able to get on the car too hard, but she spins much more freely down low.
One issue with the H-pipe.  The driver side O2 sensor bung is situated so it would interfere with the shifter linkage.  I'm gonna plug it and put a new one in that doesn't get in the way of anything.
Car Is All Back Together:D
I must say I'm VERY happy with the way it sounds and drives.  A noted improvement.  I can brake stall the converter to 2800 so everything is spot on!  She launches nicely!  Pictures and a sound clip to come a little later tonight!
Excellent! Glad you got it all worked out. I'm especially excited to hear a sound clip.
Still aint done that yet.....The wife has decided she needs the camera at work [COLOR="Red"]EVERY  DAY[/COLOR][/I][/U] in case she can put something that happens in her portfolio.
