Topic: Fila Progress Thread ( reviesed and minus all the BS) 56K death (Read 8011 times) previous topic - next topic
Reply #45
Good job Fila nice work its gonna look real good when it is done... keep us updated on any new pics..
:ford::oldcougar::mercury:
Reply #46
This thread has gone down the tubes...again.
Reply #47
Good job Mikey! Looking good. Have you removed all power components from the car? Hows the interior coming along?
Reply #48
It did get a little lost.easy to correct.back to the Fila project.Nothing more.After looking at old pics of the engine bay,and the snake pit of wires and other....srtuff,it really has come a long way.I'll be happy when I can see a cool burnout shot of this car for the first time.
Reply #49
Well, after I do some fuel line tomorow ( rubber line... meh) then we'll see vin man. Thats my big plan for tomorow.
As for the thread it can drift a bit just not too far. All about the car, why I did something, why I want to so something... just not too far off please. I REALLY want to try to document everything I'm doing to the car, and keep everyone that wants to know informed
Reply #50
Roger that.
Reply #51
Started it but not with out another problem arising. There is a VERY loud knock when the motor is running. Even when it turns over. I assume the fuel pump ( mechanical). I can't figure out why or think of anything else it could be. Other then that all new fuel lines in, motor cleaned up and running, new timing chain in.... a productive day
Reply #52
when you say "knock", is it like rod knock?
87 thunderbird turbocoupe
06 pontiac g6 gt
:birdsmily:
Reply #53
Like fuel pump. I rigged a high pressure pump up to test that, removed the mechanical pump and it stopped. Not sure what I did wrong, there is only one way to put in a fuel pump. I forgot a gasket on the timing cover anyways so it's coming back off so I can check this out ( RTV FTW!!!) Will report back in a bit
Reply #54
forgot the gasket!!! Your slipping man!! Why is there always time to do it twice, but never enough time to do it right the first time?
enough busting on you, Glad to hear your getting it done man! Hurry up! At this rate the hot rod lincoln might be done before you!
Reply #55
I didn't forget as much as I didn't put enough RTV on one side. It will be done by the end of the night. I think I figured out the prolem with the knock as well
Reply #56
Good, glad to hear!
Reply #57
I think the arm on the fuel pump is slightly bent downward.
For the record everyone,, that fuel pump came from my 306 with a cam.  If my blueracer cam "broke in" the fuel pump arm so to speak, its possible that filas cam/bell isnt "mated" to this fuel pump.  I would guess there is a gap in between the fuel pump arm and the bell when the fuel pump is in the rest position.
long story short, compare that fuel pump to a new one and see if the arm is bent downward.  Ill bet it is.
If not,, then ask if there is a canadian fuel pump for that year car and compare it to a new US fuel pump.  There just might be a technical issue here because your cam is for CFI,, (atleast i think there is a difference)
Reply #58
From what you said on the phone, the more I think about it the cam mating sounds right. I'm about to tear into this to find out so if anyone watchin will be on in an hour, I'll have pics then
EDIT:
Pics tomorow, It got cold out and I just don't wana work on the car at night.
Reply #59
Quote from: jcassity;177169
fuel pump eccentric
My guess is the bolt may be loose or backed out
