Topic: Update on My Build ! (Read 2406 times) previous topic - next topic
I have been working on the TC for almost 2 years(most of you are used to that)and I got the motor along with Stingers FMIC kit put in. and WOW is the Stinger setup NICE, it went right in beautifully !!! Looks pretty sweet too !! Well executed kit, Thanks Shannon !!
I sure hope this car runs as good as I think it looks. I mean I did alot to it.
Motors rebuilt bored .03 over
Ported and polished head and E6 manifold
Overhauled T3
Underdrive crank pulley
Esslinger timing pulleys (adjustable and idler shaft)
Full 3" exhaust, gutted cat
Gillis Valve
PE computer/MSD
Big VAM
Flowed and tested Brown tops
Relocated Battery to trunk
Remote TFI
Complete Energy suspension components
Chuck W mounts
SFC's
All sound deadening material removed
3g Alt upgrade
I am sure there is some I forgot but I dont think I left anything alone. I still have a little to go but it should be done soon.
1985 Thunderbird TC
2.3l .03 over,Ported and polished Head and E6 Manifold, LA3, T3/T4 Hybrid Turbo, Stinger FMIC, Forge BOV, Full 3" Exhaust, Essy Timing Gears & UDP's, BBK 255lph Fuel Pump, Kirban AFPR, Kirban Short Shifter, K&N Cone, Forced4 VC Vent Kit, PA Performance 3g Alternator, Energy Suspension Bushings throughout, CHE LCA's, SFC's [/LEFT]
Wow, that's looking good.  I want that car.
It's beutiful.nice job.
Nice work !!! Looks great.One problem.....there's 4 cylinders missing.
Mmm yes, might not run without spark plug wires.  But it does look amazing.  (Schwing)
 Knew I forgot something, oh yeah thats not a radiator either. Guess I ought to put that in too.
1985 Thunderbird TC
I hope mine can look that good in the future! That is sweet dude.
brian
Is that the stinger  kit or just the tubes? Looking good
looks nice
ipsd it is the whole kit
1985 Thunderbird TC
Why keep the stock airbox???
I kept the stock airbox because I have no room for the cone K&N I bought and I dont want to suck hot air in if I just mount it in the engine bay.
So I opened up the the stock airbox (ie cut out the screen) and ran a duct from the fender out to the bottom of the front valance for a cold air intake. I also put a drop in K&N in the airbox. Should work just as well as the cone.
1985 Thunderbird TC
ah makes sence. Looks amazing man. I want it!!!
But you know what, the Wiring sucks in this car ! The guy who owned this before me, bought it as the second owner in like 88 or something and he said his brother was a Ford Tech and did all the work since he's owned it.
Man he must really suck because I found so much screwed up  in this car it is freaking making me nuts!!!!!
all the wiring is rigged and spliced with those butt connectors. I have been getting rid of that  and soldering everything. Thats why I am taking so  long to get this thing running.
Geez...Ok Rant over ....thank you
1985 Thunderbird TC
