Poll
What color
Total Members Voted: 9
Topic: Painting motor parts (Read 3283 times) previous topic - next topic
I have to ask, did you take a picture just for this or did you have the picture ahead of time for just such an occasion
Well..... I got bored and sourced alot of the brackets on the car. I only really have one anymore so I found another alternater bracket, water pump, timing cover and aircleaner. All done in a matt silver/allumnium color. I don't think it looks bad. Painting the underhood matt black is soon on my to-do list to really show it off. Also got an idea on the valve covers I'm going to try. More py camara phone pics to follow soon
Edit:
Here are the pics. I also painted my set of headlight covers flat black as they should be, then threw my spair set on. Not sure which I like now though;)
And the brackets
And a spair water pump for the hell of it
should have taped up the chrome accent around the headlight buckets.
Which ones. The black ones were a form of black from the day I got the car. Looked like rattle can even then. Whats on it now ( spair silver set) is as I got it. They got some wicked fade on them. I can repaint them I just have to match the color. Doin the black paint now ( valve covers) and taping up underhood
Edit:
This is the earilest pic I can find. They were a gloss black even before I re-painted them
If you have all the oil leaks fixed, get two cans of Easy-Off oven cleaner, run the engine until it's at normal temp, shut it off and spray the entire engine with the Easy-off. Let it set for at least four hours and pressure spray it clean. It will all but sparkle.
Wow... it turned out alot better then I thought it would. I was going for this kinda look
And this is what I got
Pardon the rest of the "dirty" in these pics, It's going to be clean by the end of the day I hope
Leave those valve covers you have.  They look good.
