Bae brakes September 02, 2007, 10:57:56 PM Guys I want to know if the Baer Brake kit for the Mustang would fit for a Cougar V6, I like how that kit looks Quote Selected
Bae brakes Reply #1 – September 02, 2007, 10:59:20 PM Not without changine the spindles to sn95's... then it would work fine. Quote Selected
Bae brakes Reply #2 – September 02, 2007, 11:07:22 PM I was checking a kit and the spindles are includedQuotekit includes :2 piston PBR calipers with lightweight 2 piece, cross-drilled, slotted, and zinc washed rotors. 13" front rotors. 12" rear rotors. Front brakes are mounted on spindles already and ready to bolt on. Steel braided lines, front to rear proportioning valve, race fluid, master cylinder, bump steer kit, and dutchman hardened racing axles in stock splines Quote Selected
Bae brakes Reply #3 – September 02, 2007, 11:22:38 PM are the part numbers the same for each car? Quote Selected
Bae brakes Reply #4 – September 03, 2007, 10:26:27 AM Wow that's gonna be expensive and a lot of brakes for a little v6.Will work though if converted with those parts. Quote Selected
Bae brakes Reply #5 – September 03, 2007, 05:51:06 PM Quote from: cougarpower51;174045I was checking a kit and the spindles are includedHowsabout some info on where to get that kit. I'd be interested in one myself. Quote Selected
Bae brakes Reply #6 – September 03, 2007, 08:40:25 PM I have to imagine that is a VERY pricey kit. Also, plan on at least 17" wheels to get over the fronts. Beware of what front spindles they are giving you. Jim Quote Selected
