Topic: New Tbird Video!!! (Read 3265 times) previous topic - next topic
New Tbird Video!!!
Quote from: vinnietbird;174363
Where was the burnout?
Quote from: kingcars;174051
As for the burnout, if anyone wants to donate tires, I'll be glad to do a burnout for yas :D .
:D
New Tbird Video!!!
cool vid, but what up with shifting at 5000 hold out
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
New Tbird Video!!!
Actually, I never shifted it during filming, so it was just shifting at 4500 hahaha.  Dont worry, I still have more footage planned.  It's still a WIP.  My friend and I just wanted an idea of what we were getting ourselves into haha.
New Tbird Video!!!
Quote from: kingcars;174467
My AOD upshifts at 5,000 rpm with no shift kit:hick: . You need to adjust your TV cable.
New Tbird Video!!!
Hey do you guys ever shift to second then back to first to make it shift harder.
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
New Tbird Video!!!
Quote from: 347Thunder;174523
I can be done but I'm afraid to do it as I have a column shifter and I can easily miss a gear:hick:
New Tbird Video!!!
im actually not in the habbit of doing a lot of these runs, or at least any WOT shifts. it seems to take quite a long time. normal street driving the 1-2 shift it VERY quick, you almost dont feel it sometimes, but WOT it probably takes a full half of a second or maybe more for the RPMs to come down, signaling its now in 2nd. if i accelerate hard up to like 30 40 mph i hold it in 1st, then drop it in D while letting off the gas then cruise :hick:  dont wanna hurt it tho!!! i gotta get a shift kit so i can stop worrying about the tranny wearing out
New Tbird Video!!!
It doesn't make it shift harder, it will just hold it in second, and DONT do it, it will kill the tranny.  TRUST ME.
New Tbird Video!!!
If you get a shift kit...is that how you hold it in second? somewhere I read that shift kits allow you to do that without blowing it up.
If not how, just out of curiosty. Trans go says u can hold any gear to any rpm. So you can hold 1 obviously but without a 2 position you cant hold 2nd with the lever....
New Tbird Video!!!
To hold first and second, I have it in first, get on the gas, shift into D when it's time to go into 2nd, then when it shifts to 2nd, go back to the 1 position and then you can hold it in second.  I do this rarely (maybe 2-3 times tops since I've had the car).  I do hold first on occasion (at the track mainly), since the HO definitely has more in it past 4500rpm.
