Topic: 3G Installation Failure: The Death of a Turbo Coupe (Read 31168 times) previous topic - next topic
At the regulater? Was the car running when this happened? If it wasn't I'm not sure how this could happen.
Ask anyone who's car has burned up in their driveway overnight.  If the battery is hooked up then many relays, switches, and wires still have power.
Alrighty then, I didn't know that. I thought it had to be running to get power to the regulater.
Reguardless man, as long as your ok. The car can be replaced, you can't
After installing the Alternator, I turned on the car to test everything. It fired right up. I drove it around for about 5 minutes with the Radio, A/C, and lights on. Everything checked out.
I got back home and engaged in some celebratory beverage consumption and took a nap.
When I woke up, I heard people shouting, looked out the window and saw smoke. Lots.
After the fire was taken care of, I got to look under the hood. The Regulator and plug were gone. Melted and charred beyond comprehension. I don't know how it happened. But....it did.
-DMC24guy
[/SIZE]
Owch...
Sorry about the car, Good to hear you are ok.
I'm super paranoid about doing the 3G install now. :punchballs:
Have you over dramatized this situation?  If only the regulator and plug are gone then fix it.
I purchased a new Regulator plug from Checker Auto when I bought the Alternator. I didn't want to take a chance with my old Plug.
Perhaps....I should have.
Don't be paranoid about the install. Countless others have done this procedure and have had no problems. My car destroying fire is no reason not to install this much better alternator.
-DMC24guy
[/SIZE]
I've done this conversion many times before....  Never had an issue..
Exactly. I'm sure I probably erred at some point during the installation, and as a result, the car caught fire.
Like I said, everything seemed to work much better for those 5 minutes I got to enjoy that added power.
Unfortunately Now, I have to get a new car.
-DMC24guy
[/SIZE]
Reply #39
shiznit happens man. Getcha another Sport or XR7 then start over with a clean slate.
Maybe you weren't intended for a TC, but maybe after the insurance comes in or you get some money laying around you can fix another fox up.
Sorry bout your loss man.
Reply #40
Thanks for the Condolences. I don't know what car lyes ahead for me, but it won't be another Turbo Coupe. Evidently I was never meant to own one. Fate just has it out for me.
-DMC24guy
[/SIZE]
Reply #41
can you take some pics of the damage to save our imaginations please.
Reply #42
X2.I'll ask before anyone else does.....are you going to part it out?
Reply #43
Dude you gotta be careful howyou go about posting these little "adventures". I seriously thought the car went up like a plane crash or something...
Glad to hear its just a couple components.
Reply #44
A flesh wound.
