Topic: Addco Sway Bars (Read 1512 times) previous topic - next topic
Addco Sway Bars
Is anyone using these? I'm looking at either a replacement or an upgrade. There is a listing, but haven't heard much about them being used.
So you have a V8.......isn't that cute.
Addco Sway Bars
Why not just throw a nice painted set of TC sway bars on it?
Addco Sway Bars
He has a TC.
Ben, in these cars, the swaybars are large enough. We need more help in the springs/shocks/struts. Youve already got the rear control arms, c/c plates, and some other odds and ends. Springs, shocks and struts is where its at. Along with the subframe connectors.
Addco Sway Bars
Addco does not offer anything other than what you can find stock on a T-bird/Cougar unless you choose something from the Mustang line. I bought one myself to replace the "stocker" on mine when I had it, only to learn later that I'd just replaced it out with the exact same size bar.  Shawn is right, you would probably be better off working on other suspension components first, then come back and add in an aftermarket/larger Swaybar if you still feel that you have too much body roll.
However if you're adamant about upgrading:
http://www.foxtbirdcougarforums.com/showthread.php?t=1357
That should give you a decent head start.
