Topic: $100.00 302 (Read 9385 times) previous topic - next topic
$100.00 302
Reply #45
Specs?
What headers are those?
$100.00 302
Reply #46
Quote from: V8Demon;211590
Specs?
this is a quote from the builder
"ok Choog went with a .504 lift intake and exhaust, 110 centerline, 220 duration both intake and exhaust @ .050 lift. Cam is being ground (out of stock) should be delivered @ the 27th of Dec. All the valves have come in. Will wait to get the valve springs with the cam before the heads are reassembled. Block went .030 over on the cylinders. Crank is @ .010 under spec may have to go to .020 under. If it goes under that, we will have to get another crank. Well, I would prefer not to use a crank that goes under .020, but is still usable down to .030.
Rods have been reconditioned/resized. Pistons have been pressed to the rods with new wrist pins.
Calculated HP 320 @ 5800 rpm and 325 ftlbs of torque @ 4500 rpm. Should be close the PC dyno is a little off."
hedders
http://store.summitracing.com/partdetail.asp?part=HED%2D88380&view=32&N=700+4294839039+4294908331+4294840126+4294925044
