Topic: Engine Fan Swap (Read 3606 times) previous topic - next topic
Engine Fan Swap
I've picked up a 3G Alternator and was thinking i should go with an electric fan now.
The Metal Belt fan freaks me out anyway. :hick:
To keep costs down i would like to do this with junkyard parts, But i need some clarification as to what models and years that have the electric fan will bolt onto my stock '84 radiator.
Will any year fox Mark VIII fit? And will anything else fit other than just the elusive Mark cars?
And does anyone know if the stock relay for the elec fan will work on the swap, Or will i need to buy one from a previously mentioned site?
Thanks :D
Engine Fan Swap
I have a weird peice I found one day, a Ford Windstart dual fan on mine. It will be replaced by a raus 3.8 fan soon enough
Engine Fan Swap
Quote from: 84 Fila;172701
What in the Sam Hill does this have to do with his question? At least try to say something relevant or witty.
I need two copies of most of your posts.
One to take a dump on and one to wipe my cornhole with.
Romeo2k, is this for the 3.8L in your signature?
Engine Fan Swap
Quote from: Romeo2k;172692
... And will anything else fit other than just the elusive Mark cars?
And I answered with what I have. If it makes you fell Better Jeremy,
You can use a lot of different fans. A few to name are
3.0 Taurus fans
3.8 Taurus fans
If you can find one, a dual wind star 3.8 fan
Mark 8
And just about anything else that will fit onto your radiator.
The way I see it, you can make anything fit if your willing to make a bracket for it
Also:
http://www.foxtbirdcougarforums.com/showthread.php?t=15171&highlight=Electric+Fans
Engine Fan Swap
Sometimes it is better just to hold you tongue.
Engine Fan Swap
Quote from: JeremyB;172710
I nominate that for post of the month :hick:
Engine Fan Swap
I put one from a taurus,I think it was a 3.0?,It's wired to the low side for now.Would melt the fuse on high.It works great with the cheap fan control.Tried to run it thru a selenoid ,na thats when it melted the fuse.
Engine Fan Swap
When I installed my Mark VIII fan, I bought an install kit for it from AutoZone(Thanks Vinnie!). It works like a champ. But I need the 3g alternator too. I would go with the Mark VIII fan. It pushes so much air its retarded. They are cheap on ebay.
Engine Fan Swap
Yes it is.
Missed that when i searched, thanks.
Quote from: kitzdnm;172765
Hmm... I'll play around with the wiring/fueses and solenoids~Hopefully wont cause any damage in the process. >.<
Quote from: V8Demon;172853
Read, remember, and use:
http://www.dfwstangs.net/tech/markviii_fan/markviii.html
Thanks! I might be able to get a fan out of an 85 Mark VII~Would it have an elec fan though?
Quote from: atariman;172967
Thanks, Any idea of the part number for the autozone kit? And how much was it?
Yea i would like to go with a Mark VIII at some point, But im slightly low on funds right now~So im trying for a junkyard swap.
Marks are extremely rare around here, But the local yard is like a giant Taurus graveyard. :hick:
Engine Fan Swap
No.
Engine Fan Swap
yea mark VII are cursed with the same clutch fan.
Engine Fan Swap
hmm i might just wait until i have the funds for a MarkVIII setup from ebay or something, The taurus fans look kind of odd.
However, Would a Taurus SHO fan be any good?
They apparently have 2 fans in one shroud, Dif sizes though... Heres one on ebay:
http://cgi.ebay.com/ebaymotors/1992-1995-Ford-Taurus-SHO-Dual-Fan-3-2_W0QQcmdZViewItemQQcategoryZ33600QQihZ001QQitemZ110162483062QQrdZ1QQsspagenameZWDVW
Theres an '89 SHO at the local yard, Would it have the same style fan? anyone know?
Engine Fan Swap
Marks are extremely rare around here, But the local yard is like a giant Taurus graveyard. :hick:[/QUOTE]
I will check my receipt and get it for you. I gotta run to a doctors appt. for the wife and kid so will do it when I get back. I am thinking it was like 25 bucks or something. Not bad. Comes with everything to mount it and wire it.
brian
Engine Fan Swap
Awesome Thanks. :cheers:
Yea, Im just gonna hold out for a MarkVIII fan and the autozone install kit, Unless i find out theres something great about the SHO fan.
