Topic: Bird-interupted.. (updated) (Read 5965 times) previous topic - next topic
Started the transformation tonight
Ordered a 8 gallon and a 5 gallon fuel cell  the 8 will be for fuel and the 5 for water for the intercooler,Decided to go with 1/2 fuel line for both feed and return goit that ordered also.
Removed the following items
Rear Seat - 32 lbs
Passenger seat - 60 lbs
driver seat -80 lbs
misc junk in the trunk -34 lbs
Front seat belts -9 lbs
Rear seat belts- 4lbs
Rear plastics - 14lbs
Package tray cover -2 lbs
Rear speakers - 4lbs
Sunvisors - 3 lbs
Sunroof sheild -3 lbs
Grand total ---- 245 lbs removed
and added 13 lbs back with my kirkey race seat
3,000-232lbs  = 2768 without me!
thats some nice weight reduction. when are you gonna cage it? cause it sounds like you are gonna need it soon
Quote from: gumby;172968
Soon ive got one waiting
wow does that carb setup work for you?
Quote from: SLEEPER T-BIRD 87;172897
Rear Seat - 32 lbs
driver seat -80 lbs
Sunvisors - 3 lbs
More weight gone
Fuel tank--36 lbs
tank cover--12 lbs
fill tube,release,motor,cable etc-- 4 lbs
straps and bolts--4 lbs
Drop down in trunk floor ---27 lbs
82 lbs removed tonight
TOTAL of 327 lbs removed
Car weight 2686
Quote from: 4bangen;173127
love it
Power seats weight 60lbs? I knew they weer heavy but....well I hope that was a power seat:hick:
Quote from: thunderjet302;173227
no the power seat weighs 80 mine had the manual pass seat
all weights are from a known good scale
Quote from: SLEEPER T-BIRD 87;173230
shiznit.............
Quote from: thunderjet302;173233
I figure since im doing this id post up what all i weigh so people will have an idea!
its getting lighter! do you still have the heater box under the dash? cruise control unit? mine came in at 3020# w/ me in it with....
removed spare tire and jack
removed radio w/ speakers
removed front and rear bumper
removed front swaybar
swapped AOD for T5
removed dogbone weight off rearend
removed door panels
removed pass side and rear seat
swapped cast iron exhaust manifolds for stock mustang headers
still have a.c., power steering, smog pump, elec drivers side seat, stock k-member,  cruise control, and a lot more weight to pull out.
before the car weighed 3,465lbs w/ me in it
ive since removed the items above, but still dont have the car running to weigh it now. i have no clue what gains or losses ill see with what the car has now.
1979 Ford Fairmont
[/B]
Quote from: 32VFoxBird;173250
swapped AOD for T5
removed door panels
its still got alot in it,im still in the back half of the car right now, building a new trunk floor for ease of mounting my stuff.its also a moon roof car so its a bit heavier
Im trying to go in stages and keep track of what i remove and add
Do you still have the power windows? ;)
Quote from: SLEEPER T-BIRD 87;173194
More weight gone
Fuel tank--36 lbs
tank cover--12 lbs
Car weight 2686
Console 6 lbs
bare dash 25 lbs
heater box 27 lbs
firewall pad 16 lbs
e brake 8 lbs
steering colum 18 lbs
dash trim/switches etc 15 lbs
wiring harness 12 lbs
127 more pnds out
total of 454lbs removed
Car weight 2559
was the 1/2" fuel line a Summit purchase?  What weight are you aiming for?  Is there a difference between a sunroof car and a non sunroof car?  I just got a sunroof car, so...
1987 TC
