Topic: Stinger Performance Tail Pipes (Read 7843 times) previous topic - next topic
Stinger Performance - I will have the first set of "production" tails in my hands on Thursday. Once I look them over and verify that they are as they should be, I'll be able to get pricing figured out and then have them in stock and ready to ship on the 27th.
this is straight from NATO if any of you are following it over there.
I'm about to finish up lenthening some 2 1/2 Fox Body Mustang GT style (turn down) tailpipes for my car.  I had to lengthen them about 9 in on each side.  2 1/2 tailpipes are a tight fit on these cars, especially on the passenger side, due to the huge gas tank brackets welded to the underbody.  I had to some clearancing on the passenger side tailpipe in order to get mine to fit.  Hopefully Stinger makes a few changes to these areas for better fitment. It will be nice to have some "off the shelf" exhaust parts for our cars
1988 Thunderbird
306 HO w/ A9P processor
AOD w/ Transgo Reprogrammer
245/50/16 Tires on Snowflakes
Looks like Stinger has the tailpipes in stock now.
http://www.stinger-performance.com/stockparts.html
Got any pics with them on your car Graham?
sn95?  I thought that fox mustang pipes were direct other than the length.  I am wrong?
88 TC, Lots of Mods.
I bought a set of 2 1/2 inch Fox Mustang tails from Ebay (new pipes) withno tips or turndowns (which is what I wanted due to the tips I was adding),and they fit great.I had them extended just a few inches in the rear for the tips to end up where I wanted them.
SN95 , Fox, and '99-04 tailpipes are all exactly the same. The only difference is the hangers.
I had to "dimple" the pipe as they say on my passenger side, but otherwise they went in fairly well. I had more problems getting it to fit right around the gas tank on the passenger side.
I'm also curious as to how well his pipes fit, because if they don't fit any better than Mustang pipes...well, considering the price, I wouldn't buy them.
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
If anybody has pics of these tails actually installed-can you guys please include pics from both sides of the car.
Ken
Stingers website  is not working-Does anyone have any info on what happened?
Reply #39
I have mine installed but I need to have a ler hanger welded so they will fit right but the do fit well.
Reply #40
Quote from: 88turbo;186569
If you have the duals please post a pic. Don't the tails have the little hanger attachment already installed?
Ken
Reply #41
pic will come soon once I get them adjusted alittle better, as for the hanger they do not have one due to the difference in the hangers from 83-88.
Reply #42
Thanks for the info-waiting for the pics
Thanks
Ken
Reply #43
Im very interested in the Stinger tails as well...I wonder if they are a direct fit for the 88 tbirds ? Also, do they make an h pipe that will fit ?
Reply #44
the tails are a direct fit for 83-88 tbirds and cougars, they do not make an H-pipe but any mustang one will work with extended flow tubes. Also the stinger tail pipes are made to be used with offset/offset lers.
