Topic: Need opinions TONIGHT!!! pics (Read 2547 times) previous topic - next topic
What are the axles from? Stock length axles and typical SN95 10.5" wide wheels fit these cars very well. Are those 99-04 axles?
Yes they are 99-04 axles. I just wanted to try them since it was a good deal. I need to do some research and find axle lengths through the years. I know there is a post on here.
Jim
Ok, after some quick checks it looks like a 94-98 Mustang axle will work. (correct tbird232ci!) I measured that I could shorten up the axles about 3/4" per side. That makes the inside of the tire really close though.  So the difference from what I have to a 94-98 is 23/32"(0.71875"). Should work, so the search is on. I'd like to find a stocker before I spend money on aftermarkets though.
Quote from: thundr306;170756
Sound like a good plan.
I may have missed, what rear is in the vehicle?
