Topic: Car sputtered shut down died..... (Read 1611 times) previous topic - next topic
in the middle of base! :mad:
we had to push it uphill to park it and then I started it and it ran for about 15 seconds and shut down when I put it in gear and moved a little bit. I got it to run a little while longer for like 2 mins then it sputtered and shut down again. I think it's flooding due to the high altitude and the jets are too big here. It has never done this up here before so I am trying to figure it out. Right now it is sitting in my work parking lot.
What does everyone think?
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
1988 Turbo Coupe (RIP)
Check the spark plugs to see if they are covered in fuel...if so it's way to rich
1988 Thunderbird
306 HO w/ A9P processor
AOD w/ Transgo Reprogrammer
245/50/16 Tires on Snowflakes
I had a feeling that might happen eventually but not this soon. I suppose I was running extremely rich. :toilet:
Why can't I be extremely rich? :hick:
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
It sounds like mine when the ignition module failed too.
No, please dont tell me it's acting up again!  After all the  we went through getting it running the first time.  Ugh, lame!  I sure hope it's not a hard fix, though.
Quote from: Carl;169928
a M90 will lean it out a bit. ;)
1979 Ford Fairmont
[/B]
FIXED! Like 5 mins after I posted the thread lol. The ground came off the fuel pump. :hick:
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
Quote from: Carl;170019
*sigh* :punchballs:
I was going to say it sounded like you were not getting fuel..
