Topic: Turbocoupe Cluster Swap (Read 2120 times) previous topic - next topic
Hey guys I'm expecting to receive a TC cluster sometime in the mail this week and before it got here I wanted to ask  a few questions.
1) How do I size the faces on the website to the correct size? As of now when I print them off they are about 8 inches in diameter.
2) Since I currently have the base cluster how do I run a wire for the tachometer?
are you building a boosted 5.0?
87 thunderbird turbocoupe
06 pontiac g6 gt
:birdsmily:
In your print dialog box (assuming it's Acrobat Reader), make sure you UNCHECK the boxes for "Auto Rotate and Center" and "Fit To Page" (or equivalent). This will give you a 100% printout.
Tap onto the dark green/white wire at the ignition coil (+).
Quote from: EricCoolCats;168432
Correct wire color, but the polarity is (-).
Thanks guys!. And no it is currently just a NA 5.0 it will be a while before I go ahead and turbo/boost it so I will be eliminating the boost gauge for now.....but later on, much much later on there will be a turbocharged 331 with a viper transmission and cobra independent rear suspension. Right now though I'd be happy with a paint job :bowdown:
Weeeeell tried to open the jpg with adobe and it can't open it sooo any other ideas?
Peel the faces off and scan them? lol thats what I did. I need to make another set for the car. So I may be able to do that to help ya out.
How soon do you need the faces?
I need them eventually but right now I don't have even have the buttstuffogue cluster so no sweat. Still though I'd like to go 140mph so I need to figure out hows to print these up. bleh
Yeah Um problem here... Acrobat reader won't open jpg. files. So how exactly do I manage to print these bad boys off?
Auto resize is turned off in the browser, and I saved the image as a PDF and went to print it out in Adobe and I still get a printed image twice as big as I need it. :punchballs: :punchballs: :punchballs: :punchballs:
