Topic: New and used parts for sale, rare and performance (Read 3636 times) previous topic - next topic
lol ok nvm then, figured that would be a nice gift for my dad
Quote from: Aerobird Motorsports;167579
That's funny Carm! What, do embarrassed for pics? ;)
You want a pic? Here's a pic :hick: I'll either need to drop its butt or install something like 265/70R16 truck tires on the snowflakes to fill those gaping wheel wells...
holy hell!! thats all the way down? time for new springs/ or some drag slicks!
Quote from: Thunder Chicken;167439
I'm actually kinda regretting buying my adjustable ones. The arse sits too high now, gotta get some shorter springs :hick:
...and by "too high" I mean "WAY TOO HIGH" - the 225/60R15 tires look like donut spares in the wheel wells now...
After seeing the pic.. is this what my CHE non adjustables will look like?
LOL! :hick: That's funny Carm! Time for some shorter Mustang springs ;)
Quote from: daboss351;167642
That is all the frickin' way down. Stock '87 Turbo Coupe rear springs...
Quote from: 84 Fila;167643
No. The adjustables add about an inch (or more, it seems to me) of height for the adjustment mechanism. The non-adjustables should have the car sitting at stock height.
what does a 83-84 TC gauge pod look like..... is there a pic around i can check out?... is that rpm, fuel and speedo?  will it work with the aod speedo cable?
It has a tach and speedo and a boost gauge in it. I can snap a pic of the one I am selling.
The 83-84 TC cluster should look like a big speedo big tach, gas gauge in the middle. Then it has a green light for Boost and a red light for Overboost.
Yep, that's it exactly. Putting that cluster in a non-turbo car will result in the loss of a factory transmission gear indicator, though, since the fuel gauge is where the indicator is in non-turbo clusters.
Quote from: EricCoolCats;167743
no need, i have a floor shifter :)... could i swap it with my cougar digital dash.... i'm sure they'll be some wires to swap, but they'll fit and the speedo will work right?.....  if so, i'll take that pic ;)
I know the one in my 84 T/c is a cable driven speedo. I think that the end that goes into the speedo are all the same. except the part that holds them onto the speedo.
My speedo cable is melted but still works. If my cluster comes out it's not going back in. I'll opt for the TC cluster when I replace it
*smacks forehead*
I totally spazzed on that... Stupid Auto... :p
If you take pics of the one your selling, Can you get one of the back for me please?
Want to make sure i put it all back together correctly. :hick:
Mike, do you have an 87-88 T-Bird driver's side quarter panel trim piece? I need a non-TC one with no cracks or chips. Mine has a hole in the front and it's been letting water in, which is one reason why I've got rust there.
5.0L Speed density
Explorer intake
'92 Mustang GT cam
GT-40 racing heads
Unequal length headers
Custom-made duals
19# injectors
65mm TB
AFPR
T/C header panel
11" brake upgrade
T/C rear sway bar
