Topic: Very angry... (Read 3308 times) previous topic - next topic
Very angry...
Fan is a Flex-lite with a 2 1/2" spacer, no clutch. The fan and spacer are fine. The bolt holes in the w/p pulley are pretty badly chewed up, I don't trust it. The water pump is a Jegs aluminum high flow one bolt hole is chewed up, I don't trust it. I'll replace the pulley and pump in a few weeks after a I get the other Cat. When I replace the pump if someone really wants it I'll sell it for $40 and give you the pulley for free.
Very angry...
you think the pump can be made usable? that would be a nice cheap alternative for me since my pump is leaking out the weep hole
Very angry...
Quote from: daboss351;167617
Only way I would trust it would be to drill all four holes perfectly straight and tap them for larger bolts. Any other way I would not trust for either strength or balance. And out of balance fan is going to destroy the pump pretty quick and if it isn't strong enough you may end up with your fan sticking through the hood.
But you're welcome to try.
Very angry...
If it's the stabilty of the fan your worried about... why not just go E fan? Or is it the rigity of the bolts holding the pump pully to the pump itself?
Very angry...
im gonna be running a e fan so theres no problem there! let me know when your getting rid of it!
