Topic: Intake spacer and other upgrades (Read 8684 times) previous topic - next topic
Reply #45
i stand corrected
1988 Thunderbird sport
2004 Ford F150 Lariat
2008  Chevrolet Cobalt Sport
1988 Thunderbird LX - sold
Reply #46
Quote from: kingcars;168123
Yeah that stuff is a bit outta my price range.
Yeah, unfortunately going fast costs. $. You could save up and do it right with some of this info or work the stuff you have now. The tfs kits are impressive with out a doubt. 350+hp. Anytime you are over a hp per ci is good. Makes you really appreciate what the 4 cyl. guys are able to accomplish.
Reply #47
cheap HP
UPR cold air fender well kit
also i got a 255lph fuel pump helps a lot
Try and get a E303 cam or something a step-up form a B-cam
Reply #48
Quote from: Carpimp1987;168378
The "E" cam is milder than the "B"...
Reply #49
Not according to the alphabet!
Reply #50
That's why i wanted an E cam.I can't have too radical with flat top pistons.Heck,I don't even know if the E will work until I throw it in and do a PTV check.I'll post when it happens.
Reply #51
Quote from: vinnietbird;168553
please do, im very curious if any other cam will work with a SO bottom end besides a HO.
Reply #52
Quote from: Tbird232ci;168545
LOL...
Reply #53
Rumor has it that it will clear, but every engine and every head is different.
Reply #54
Don't get me started :hick:
Ford and the alphabet  :beatyoass: :punchballs:
Reply #55
Quote from: t.birdsc;168593
Lol throw the alphabet out the window when talking injectors. go by color only.
worst gray,better orange/yellow, even better red, and green the best.
 If buying the injectors from Ford, open the box 1st then you know. :D  :hick:  :D
Reply #56
You forgot blue:hick:
Funny, blue is 24 pounds/hour on the 5.0.  My Stang has 34's now.....they are also blue.  Much different in appearance, but the same blue.
Reply #57
Quote from: V8Demon;168697
 I did! lol  :toilet:
Reply #58
Alright guys, I bumped the timing to 14 deg BTDC this evening and she definitely feels better at higher rpms.  She runs right to 5500rpm without problems.  I plan to go to the track tomorrow to see if it translates to better numbers.
So anyways...what's this I'm hearing about putting an E303 cam with an SO bottom end?
Reply #59
Quote from: kingcars;169371
Same as before, you can run about any cam that's streetable with the E6s... I can't see it happening with E7s
