Topic: back to stock (Read 4584 times) previous topic - next topic
back to stock
i thought gears would help alot too and ive planned for 3.73's too be next on the list of things to do for a while, but after getting those heads, im leaning to a full HO swap. im very torn on what to do. if im gonna put a cam in, i want something a little more then a plain-jane HO cam. but with SO pistons i dont have much choice, and i really dont wanna tear it down completely for new pistons. so i think i'll go regular Ho swap (cus i dont have much other choice). and then later go 3.73's.
a 2400 stall converter? whats in there stock? and how much of a pita would it be to put one in? i gues about as hard as pulling the trans?
1988 Thunderbird sport
2004 Ford F150 Lariat
2008  Chevrolet Cobalt Sport
1988 Thunderbird LX - sold
back to stock
Quote from: SSX;165816
fwhp=flywheel horsepower in this case.
yea, flywheel. not front wheel.  sorry for the confusion
back to stock
Dude, don't get down if anyone is pissed after their mods it was me. 1st mod to bone stock 88 5.0. Paxton sn2000. Didn't feel much different. Call the supplier. You don't have a gear or a motor. Ho top conversion and 3.73 gears. Go to the track. 16.5. You wanna talk about pissed. Granted it wasn't tuned,  exhaust and the tires weren't helping but still 86mph at the traps :(
 You're doing far better than I for less money. Just my 2 cents.
back to stock
I still have an HO computer laying around.
2400 stall is a baby compared to what the "fast" guys run. Good street manners, yet will still make a huge difference.
back to stock
Quote from: grutinator;165909
Stock is approx 1600/1800... Yup have to pull the tranny...
It's a definite "to do" when swapping engines...
B&M sells a cheap 2400... Everybody will yell junk, but I had the 2K version and sold it to chrome302jr... He sprayed the hell out of it and that converter never hiccuped... For a fairly stock NA engine, I'd buy another one...
back to stock
Quote from: turboranger91;165850
gotcha... i've been hanging around the honda boys too long!:punchballs: :hick:
YEP!!This is Ford world..
back to stock
1.7 ratio roller rockers would be a good and relatively inexpensive upgrade you can re-use on E7's, GT40's and other heads as well.
back to stock
Quote from: Tbird232ci;165940
i may be interested in that. what year is it from? and  how much?
Quote from: TurboCoupe50;165975
if i ever pull the engine ill try to do that, but i dont really plan on doing that anytime soon unless i find a good deal on a mark/stang HO.
back to stock
Quote from: V8Demon;166019
yea, evrything im reading says im gonna have to do something about the pistons. between a cam i want, milled heads, and 1.7 rockers...im gonna need some more clearance
back to stock
Its from an 87 Mustang, also has that chip we discussed. Its speed density, so itll be a direct swap.
back to stock
ok shawn, we talked, now i gotta ifnd time to get it.
i still have trouble beliving that it runs high 16's. whats stock for an 88 5.0? the kid i work with brought in his dad 2000 4.6 5 speed convertable stang for an oil change, he kept saying how slow it was and gave me a ride in it to show me. i think its safe to say that a car like that would rape mine. pretty sad to know youd lose to a car tha some poeple think is 'slow'.
back to stock
Ha, thats funny.  Considering my car makes 20 less Hp than you. AT THE CRANK.
back to stock
Quote from: grutinator;166250
Got a Hot Rod mag around somewhere with '87 TC vs 5.0 test(not where it thought it was)... I believe the times were approx 16.2 -16.4 with the TC edging out the 5.0...
Here's some Bird times I found on the net... First time is 0-60...
The '96 LX must have been a ringer, cause I don't think my '95 would run 15s, Woof Woof, Bow Wow(dog)... It does go fairly well when I gag it, just doesn't seem to have much before WOT...
1955 Ford Thunderbird 292ci 11.5 18.0
1973 Ford Thunderbird 460ci 9.0 17.4
1980 Ford Thunderbird 302ci 11.1 18.0
1983 Ford Thunderbird Turbo Coupe 9.7 17.1
1987 Ford Thunderbird Turbo Coupe 8.5 16.3
1989 Ford Thunderbird SC 7.4 15.9
1990 Ford Thunderbird SC 7.4 15.8
1991 Ford Thunderbird LX 9.0 16.7
1993 Ford Thunderbird SC 7.2 15.7
1994 Ford Thunderbird LX V6 8.8 16.4
1995 Ford Thunderbird SC 7.0 15.2
1996 Ford Thunderbird LX V8 7.9 15.8
2002 Ford Thunderbird 7.0 15.2
back to stock
that stang has 260 hp stock. thats over 100hp more than a cougar.
Think of this. Stock Mark VII's have the 225hp HO. They run the 1/4 in around 16.2-16.4. Youre running just a little slower than that in a car with maybe 180hp and probably only weighs a couple hundred lbs less.
back to stock
Quote from: bhazard;166257
yea, i like the way this sounds better.im really close to beating a stock mark, rather then no where close to a stock mustang. and if, just for arguing, im 300 lbs lighter then a mark, and i do a regular old HO conversion, that should put me right at 16.0(give or take). i'd settle for that.
