Topic: A no option car (Read 4279 times) previous topic - next topic
A no option car
It's right there in Gray cloth, a no-tilt column , first one I've ever seen.
A no option car
My '85 didn't have tilt, and come to think if it, I think my 88 Cougar didn't have it either.
My '85 also didn't have intermittent wipers. That's gotta be a rare one.
A no option car
This car and the Med Red V6 I posted a few months ago both had non-intermittent wipers. Those are the only 2 I've ever seen, so yeah it's rare!
A no option car
Wow is that ever plain jane thought mine was hardly optioned
1988 Mercury Cougar LS 5.0L AOD 2.73 :cougarsmily:
1993 F150 XLT 5.8L E4OD 3.55
A no option car
My 83 doesn't have intermittent wipers.
A no option car
Quote from: CougarSE;164512
Yeah but it doesn't have any power either... ;)  LOL.
My '85 didn't have them too.
A no option car
Quote from: Aerobird Motorsports;164153
Yeah it's definitely strange. The radio, heater, and license plate bracket were all $0 so that accounts for them. I don't know whether or not it has A/C, or whether A/C cost $. The no-tilt is something I didn't even know existed, which is pretty cool. The passenger mirror missing is fairly uncommon as well.
I'm not which heater you’re referring to. Are you talking about an engine heater? If so, that was a charge option.
Air conditioning was standard equipment.
A single driver side manually controlled mirror was standard. Dual electric mirrors were an option. (you could not get dual manual mirrors)
This is all pertaining to a base Thunderbird. If it were a LX model, the tilt wheel, and dual electric mirrors would be standard equipment.
Same with the delay wipers, optional on a base car, standard on the LX model
Brent
:cougarsmily:
One of 1,246 built
A no option car
Quote from: BCA;164559
Nope, I present to you, dual manual mirrors:
http://www.foxtbirdcougarforums.com/showthread.php?t=12577&highlight=optioned
And I was speaking of the in-car heater. I've seen at least 3 84-84's with no a/c from the factory, but I have no idea if a/c was standard on 85-88's.
A no option car
A/C was optional on 85-88's in Canada. Pretty sure it was standard in the USA. Guess Ford figured that if we Canucks wanted to get cold we'd climb back into our igloos.
Also, the engine block heater and rear defrost were standard equipment in some areas, Eastern Canada being one of them.
A no option car
Nope, as Brent said, you could NOT get factory dual manual mirrors.
Ford provided kits to add things that were deleted from factory cars. If you had the radio delete (with block-off plate for the radio hole and the antenna hole), Ford made available an antenna kit using OEM parts. Same went for the passenger side mirror. That car originally had only a driver's side mirror and a block-off plate on the passenger side, and then the aftermarket Ford mirror kit was installed on the passenger side sometime after purchase. Whenever you see two manual mirror adjusters in a car, that is the ONLY possibility.
A no option car
Aaaaaaah I see said the blind man to his deaf dog :hick: Well there's a factory added double-manual mirror then :hick:
I'd imagine that the no-A/C 83-84's I've seen were either A: from Canada, or B: sols like that up here in the arctic tundra anyways. It was an 83 TC, an 84 TC, and an 84 elan 5.0, and I remember the Dark Blue elan having rear defrost.
A no option car
My 86 didn't have tilt, or a passenger side mirror. aslo didnt have any power anything, no rear window defroster... And alot of things I can't thing of.
The only two options I figured on my car was the 5.0(I was told that a/c was standard on the 5.0 in the usa...) and some sort of towing package, only because I had the 10" rear brakes. Other then that, no options that I can think of.
A no option car
That T-Bird's interior is a match to my '86 Cat which is a pretty close match to Haystacks car.
Mine has no rear defroster, no passenger mirror, no cruise, no tilt, manual mirrors, manual seats, manual locks, no map lights just a flat square dome light.
It just has an optional 5.0, 7.5 Traction lock and the TRX package.
A no option car
Quote from: Aerobird Motorsports;164885
Mmmm, no-option 5.0 Cougars... :D
I didn't say my car was no option ;)
Just that the interiors matched.
I will clearly admit that I don't think I've ever seen an '87-88 car that stripped. Usually I only see it on '83-86s.
