Topic: Making some progress- FOR SALE (Read 52846 times) previous topic - next topic
Reply #225
I would bet his block is in pretty good shape. He gave some top end parts out of it, and they looked brand new. Looked like you where smokin the wheels on the dyno.
Reply #226
I just found out that the MD dyno that I was on reads about 12% lower than the Dynojet dyno. I wish I had been on one of them instead....530rwhp@5400rpm sounds so much better!!!
I have been looking around at short/long blocks. The ones I want are way too much money. Looks like I am going to be looking for a used block or I'll have to see if mine can go to .040 over!
Reply #227
That is a really good looking car!! Very very nicely done!! Keep it up, that car will be worth it!!
1985.5 SVO
Reply #228
Quote from: thundr306;245388
I have hear you can go .060 over! Not sure if its true but Im sure .040 wont be bad, even under boost.
Reply #229
100 bucks and i can get it to PA
Reply #230
Quote from: daboss351;245467
I doubt that I will go that way....sorry.
Lucky cylinder number one has 40psi!!!!!
Reply #231
Quote from: thundr306;245495
Hey Jim,
Sorry to see this.  I guess it will be a long winter.
Reply #232
Quote from: Sluggo;245501
Hey Jim,
Wow, you still around??? Yea, it's a bummer.
Reply #233
yea I didnt think so. I mean I really just want the block gone, if you really need one, I could just send it down there just to get it gone. Its hogging my engine stand, oiled up in a bag.
Reply #234
Had the head checked and all was ok. Looks like bottom end issues. I had an idea that was the problem, but didn't want to accept it.
Reply #235
Quote from: thundr306;245829
No sighn of anything in the cyl.
Reply #236
Quote from: Kitz Kat;245832
Cylinder looks ok. I'm going to try to pop the piston out with the engine still in the car.
Reply #237
Quote from: thundr306;245982
With the subframe member you put in you might be able to pull the pan. You may need to raise the motor a bit.
I'll be going bye sat. if you need some help.
Reply #238
Quote from: Kitz Kat;246010
Thanks. If I can get out there tonight, I am going to give it a try. It looks like I will have to lower the steering rack. The tubular k-member has plenty of clearance to the oil pan.
Reply #239
wish you the best!
