Topic: escorts.. (Read 3231 times) previous topic - next topic
escorts..
the first generation, 81-90... were they rwd?  i know the cosworth escorts were if not AWD.  wouldnt a fox TC engine drop right in?  (if it is rwd)
on a side note, refering to a really small light car..  how is the TC 4 cyl in n/a form? (havnt gotten the rule book, but i might use one if not mustangs.  its a rwd 4cyl class with small cars like that wth n/a engines.)
escorts..
american escorts were fwd.
cosworths are a totally different animal
escorts..
Of course you could import an early 70's Ford Escort, and soup it up FTW
1987 TC
escorts..
My mind is in the gutter.
I thought he was looking to pay for an evening's entertainment.....
escorts..
yeh i figured those cosworths where a whole different animal.  i mean i havnt KNOWN an escort to be RWD but cosworth was building shelby dream it seems.  if i were to import a vintage car... it would have to be datsun 510 rhd with a 2 or more rotory.
to me, jdm spec hatchi 86 with 3 rotor would put any car away.  p/w ratios like a sportbike. road spec race car :D
escorts..
Over at turbo ford there is someone that turboed there 1.9L escort motor. I heard it rips.
escorts..
my brothers escort is a 1.9 i cant belive someone would turbo it, it seems weak.
escorts..
Quote from: Autocat;163133
Ummmm....  I'm confused. Datsun 510s came with a 1.6L and later 1.8L four cyl. Are you going to swap a Mazda engine into it?
escorts..
Quote from: Autocat;163110
If you want a small RWD Ford that a 2.3 will bolt into you need only look as far as a Pinto :hick:
As for a NA TC engine, I'd guess it'd have even less power than a 2.3 Mustang engine. Not 100% certain, but I'm thinking that the turbocharged versions of the 2.3 had lower compression than the N/A version. I know (from experience) that the 2.2 turbo Dodges are absolute dogs when the turbo is taken out of the picture (or, in my personal case, the turbo outlet hose blows off because somebody forgot to tighten the clamps holding it on)
escorts..
Total dogs. I drove my N/A for a while, and id have to floor it to get up to the speed limit.
escorts..
I read about a 1.9 turbo in a tempo...
turbo 1.6 manifold, 2.3 tc wiring and computer. Dunno about the rest...
escorts..
Quote from: daboss351;163159
Look at NA 2.3's once...
escorts..
i ment the block and such. not as weak in power.
escorts..
speaking of escorts..........
this is my brother's. :shakehead
1979 Ford Fairmont
[/B]
escorts..
My grandparents had an '84 base and I mean base model Escort when I was little. I had the base engine, crank windows, a heater, and an AM radio. That was it. It was also a two door. Worst car ever. It always broke down and it rattled and buzzed like you wouldn't believe. I'd never want one of those, even if one could be found now. They bought it as a put-put car for around town. They also had a fully loaded '80 Olds 88 Royal for trips and *fancy* outings. The Olds was a much, much, much nicer car.
