Topic: The saga of the '83 2.3T (Grab a beer and a snack) (Read 4812 times) previous topic - next topic
Quote from: turboranger91;173110
that looks great, chuck.  so you're not doing anything else to this head other then cleaning it up and mildly porting it?
Nope...
Ok, well I finally got the porting work done on the replacement head today.
Nothing fancy, just some mild port work.  One thing I did do was raise the roof of the big radius on the ex port to try and help smooth the flow.  I basically just raised it by 1/8".  Hard to really see in a pic and I forgot to take a side-by-side one.
Next item is the little work for the oil-control cam bearings (which deliver the oil to the top of the cam bearing where the load is instead of the bottom.  Then it's off to be faced and then time for reassembly.  I went ahead and picked up a set of drop-in springs with a higher seat pressure as well.
looks great. i need to do that to one of my spare heads so it will be ready if/when i pop a HG
ok,, i need some help here,,,,,,,,,
thats considered a MILD port job?????????????
id hate to see a major.
good job man,
Quote from: jcassity;175215
good job man,
Yeah "major" would have involved removing the valve guide bosses completely, hogging the bowls a bit more and REALLY opening up the exhaust port (enlarging the diameter as well as raising the port roof) ;)
Still std-sized valves too.
Quote from: Chuck W;175220
if you want,, i have a real nice set of valve seat cutting tools made by Neway if you want to borrow them.  Theres about 12 dies and guides with a T bar.  I can borrow it out to you till i need it back.
Quote from: jcassity;175237
I appreciate the offer, but I didn't plan on doing big valves in this head.  I just want it back on the road.  I just had a serious mental block with dropping a BONE STOCK head on it.
what does polishing the combustion chamber do ?
Quote from: CougarCoupe88;175274
Helps against carbon build up.
Reply #39
what chuck said, but it also helps to prevent detonation by reducing the the chance of a hot spot due to as cast roughness
louie  :birdsmily:
My famous last words:
Reply #40
That's a lot of work for a "temporary" engine. :p
j/k looks good.
Reply #41
ahhh i see . thanks for the info
